What octane rated fuel do you use?
Old May 1, 2009 | 10:18 AM
langjie's Avatar
Default Re: What octane rated fuel do you use?
Nope, but as an engineer, I can tell you that it will only make a difference in your wallet and not your fuel tank
Old May 1, 2009 | 10:42 AM
cephraim's Avatar
I've read some contradictory results on other forums for other cars.
Would really like to get some empirical data for this car.
Eph
Old May 1, 2009 | 12:38 PM
langjie's Avatar
you could try it. I think any improvements in efficiency would be minimal though.
Old May 1, 2009 | 12:54 PM
Mendel Leisk's Avatar
Danny, I don't think a higher compression engine takes advantage of something in higher octane gas. My understanding:
Higher octane gas is primarly different in that it's harder to ignite. This is a requirement for higher compression engines where there is an increased likelyhood of glowing carbon deposits (or whatever) pre-igniting the fuel/air mixture before the sparkplug does (causing knocking or backfire).
Bottom line: if you don't have a high compression engine, and your owners manual recommends regular octane, and you're not experiencing pinging/knocking, higher octane fuel is a waste of money.
Old May 2, 2009 | 07:16 AM
Ed_T's Avatar
TCH 2007 newbie May 07
Well in my TCH I was getting some knock under load in hot weather. I switched to 89 octane and the engine feels livelier and I will only get an almost inaudible ping here and there (Toy manual states this is normal.) I think timing was greatly retarded with the 87, much less so using 89. Night and day. I ran a tank of 87 awhile ago and the engine clearly felt "dead". Couldn't wait to burn it off.
The manual recommends "at least" 87 octane - intesting way to put it.
12.5:1 compression ratio.
Not sure about the Nissan specs.
Old May 2, 2009 | 08:45 AM
Different octanes might come from different sources as well, introducing more variables.
Old May 3, 2009 | 09:31 AM
lloyd123's Avatar
The NAH has a 9.6:1 ratio. That's the same as the conventional Nissan Altima and Toyota Camry engines. The TCH has a modified atkinson cycle engine which has a lower compression at slower speed and light load and then raises the compression under load - similar to what you described.
I don't see the advantage of this if you have to use a higher octane to eliminate the pinging. Are all TCH's like this or could you have a problem with carbon deposits or your timing might be off?
Old May 4, 2009 | 01:27 PM
langjie's Avatar
I just mean that it can unlock the potential of the higher octane gas into useful work.
Old May 9, 2009 | 10:34 AM
cephraim's Avatar
Filled up with 93 on the tank I just started. After 100miles, I am seeing 49mpg+ on my car's gauge. This is about 3mpg than I saw on my last tank. Of course, it's too soon to know for sure. I'll report back when I get through the tank.
Eph
Jay_Taipei
Lexus RX 400h
Apr 25, 2010 01:45 PM
Ed_T
Jun 11, 2007 05:00 AM
TKCamry
Nov 22, 2006 07:07 AM
noflash
Nov 10, 2006 09:15 PM
Delta Flyer
Feb 13, 2006 03:14 PM
