Vent Fan
Old Aug 12, 2009 | 11:11 AM
langjie's Avatar
Default Vent Fan
So did anyone here ever bother installing a fan for the vent behind the backseat to the battery? If they did, does it work well? Also, how did you wire it and mount it? I'm just interested because I feel the need to do it.
I'm referencing this old thread...
https://www.greenhybrid.com/discuss/...braking-15165/
Old Aug 13, 2009 | 05:54 AM
cephraim's Avatar
Default Re: Vent Fan
No, but I am definitely interested in a cooling fan and a heating fan to heat the battery in winter.
Old Aug 13, 2009 | 08:56 AM
langjie's Avatar
do you think it's really necessary for a battery heater? A heating fan would probably consume more electricity than any additional savings you would get from a quicker recharge.
Old Aug 13, 2009 | 09:03 AM
cephraim's Avatar
I'd use a solar panel for power.
Old Aug 16, 2009 | 06:35 PM
lloyd123's Avatar
I think that would be redundant as there is already a cooling fan built into the battery module.
This is from the shop manual:
System Description
• The HV ECU monitors rises in the battery temperature through the four temperature sensors in the HV battery module. Then, the hybrid vehicle control ECU steplessly actuates the cooling fan under duty cycle control, in order to maintain the temperature of the HV battery module within the specified range.
• While the air conditioning system is operating to cool the cabin, if the HV battery module temperature is within a normal range, the hybrid vehicle control ECU turns the battery cooling fan OFF or changes the fan speed to low speed. The purpose of this control is to give priority to cooling down the cabin, which also provides cooling to the battery module through the intake duct located on the center of the rear package tray
trim.
http://i13.photobucket.com/albums/a2...erycooling.jpg
Old Aug 17, 2009 | 08:08 AM
langjie's Avatar
really? it doesn't seem to be very effective in the summer.
thanks for sharing this info though
Old Aug 17, 2009 | 11:32 AM
lloyd123's Avatar
Here's another image from the manual. There appears to be actually two fans - one for the battery and another for the converter.
http://i13.photobucket.com/albums/a2...rge/hybrid.jpg
yu888
May 19, 2010 11:35 PM
Scuddy
Jul 17, 2007 07:17 PM
jbollt
Nov 9, 2006 09:54 AM
jahwerx
Oct 20, 2005 11:52 AM
impala
Jun 16, 2005 11:13 AM
