2008 hybrid: Replacing OEM headlamp bulbs
Old Jun 2, 2009 | 09:42 AM
rps944's Avatar
Lightbulb 2008 hybrid: Replacing OEM headlamp bulbs
Here's an FYI regarding headlamp bulb replacement: First, as most of you know, you have to go in through the wheel wells to replace the low beams. While you're in there, you can also replace the high beams but that can be done (not real easily) through the engine compartment if your hands aren't too big.
Anyway, on the 2008 hybrid (I don't know if this is valid for any other year), the owners manual lists H1 and HB3 lamps as the bulb types. WRONG! The correct bulb types are H11 and H9. I replaced mine with PIAA Xwhites last July and so far, so good. I don't know if H9s are being used regularly in autos now - I learned that they are used primarily
in motorcyles and are sold in single units, not a pair (at least that's what I found last year).
I hope this info helps someone to avoid the mistake I made: looking up the bulb types in the manual and then ordering them, only to find when I go to replace them that both sets were wrong. If anyone's interested, I have a new pair of PIAA Xwhite H1 and HB3 available cheap
Bob
Old Jun 3, 2009 | 06:32 AM
cephraim's Avatar
Default Re: 2008 hybrid: Replacing OEM headlamp bulbs
Thanks! That's great info!
Old Jun 14, 2009 | 09:25 PM
mean-boy's Avatar
Has anyone installed xenon in the NAH? I've seen posts where regular Altimas owners installed xenon lights either through kits or headlight housing conversions.
Old Jun 15, 2009 | 07:30 AM
langjie's Avatar
Yes, I have
Old Jun 15, 2009 | 08:50 AM
mean-boy's Avatar
Did you use the OEM non hid housing or did you change to the OEM hid housing?
Old Jun 15, 2009 | 10:32 AM
langjie's Avatar
Yeah, the factory non hid housing. I think there is scatter so I try to point my lights a bit lower. I wish HID's were a factory option, oh well
Old Jun 15, 2009 | 04:30 PM
mean-boy's Avatar
There was a write up using the 3.5 SE xenon housing and it didn't look too complicated except for the bumper removal. I think the used headlights with ballasts and bulbs were $450 or so. There was a small cost for the wiring harness. I don't think this was done to a NAH but a 2.5S.
Jason Nipp
May 17, 2012 12:45 PM
mikieboyblue
Jun 26, 2009 03:47 PM
bajer
Jan 13, 2008 02:53 PM
worthywads
Off Topic
16
Jul 30, 2007 11:10 AM
Island Mariner
Dec 12, 2006 07:40 AM
