08 NAH Techincal Service Bulletin?
Old Jul 27, 2008 | 07:51 AM
lloyd123's Avatar
Default Re: 08 NAH Techincal Service Bulletin?
Originally Posted by nicholus
It's not a recall. It's a service bulletin - meant to advise service techs. Basically it says that if the 12V battery ever goes bad, that it shouldn't be replaced with the same kind - but rather the updated model. Until your 12V battery goes bad, don't worry about it.
I'm not 100% sure the Optima is an update rather than just a direct replacement. I believe the Panasonic battery is the same construction as the Optima (just can't remember where I saw this info) and that Nissan is now recommending the Optima instead, perhaps, because it's easier to find as it's stocked by most auto parts stores in the US. I'd be interested to see what comes as OEM in the 2009 or even the last of the 2008's.
Both the Panasonic and the Optima are "absorbed glass mat" batteries:
http://www.daviddarling.info/encyclo...glass_mat.html
I think that's why you have to be careful on how you charge them.
Old Jul 30, 2008 | 06:24 AM
lloyd123's Avatar
Originally Posted by steved28
****! I KNEW they should have been putting deep cycle 12V batteries in these things. This service bulletin is to replace you battery with an Optima battery.
The TSB doesn't indicate the exact model Optima battery Nissan recommends but it does show one with a red top. I was looking at the Optima website and the red top batteries aren't the deep cycle version - the yellow top models are.
http://www.optimabatteries.com/optima_products/
Old Jul 30, 2008 | 07:14 PM
steved28's Avatar
If that is the case it's very disappointing news. Why does this battery need ANY cold cranking amps? As far as I know, it does not turn the engine (there is no starter motor in the NAH). So it needs to hold a charge for prolonged periods of sitting, and it should be able to operate the 12V devices for long cycles where it may not receive a charge. Perfect application for deep cycle batteries! I have used Marine batteries in my truck (which is used for emergency services and has an 1800W 120V inverter) and never had a problem. These batteries far outlasted the original equipment "thin plate" battery in applications that put prolonged drains on the battery. (sitting hours with emergency lighting on and using 120V devices via the inverter)
valmar
Nov 22, 2012 06:55 AM
Magnoliasteve
Sep 23, 2008 10:11 AM
blagor
Jan 20, 2008 05:41 PM
Jason
Hybrid & Related News
Feb 15, 2005 08:06 AM
Jason
Jan 12, 2005 07:10 PM
