Mystery Mariner Malady
Old Aug 10, 2019 | 02:29 PM
Hippo the Hybrid's Avatar
Default Re: Mystery Mariner Malady
GRAFXMAN, can you copy your PCM and BCM information from FORSCAN and post? I would like to compare the full results against a 2010 FEH, aka Hippo the Hybrid.
S. Keith, thanks for the insight into your personality profile! Without your help, this forum would be as obsolete as a 2005 FEH.
Old Aug 10, 2019 | 03:54 PM
grafxman's Avatar
They're listed above in post #3.
Old Aug 10, 2019 | 06:53 PM
The FORSCAN PC version should give you the following output or similar from the BCM battery control module. It would be also good if you post the PCM powertrain control module info too.
P0A1F_01_CM No Fault Pack Voltage Measurement Error
P0A1F_04_CM No Fault (-) Contactor Voltage Sense #2 Fault
P0A1F_05_CM No Fault (+) Contactor Voltage Sense #2 Fault
P0A1F_06_CM No Fault (-) Contactor Voltage Sense #1 Fault
P0A1F_07_CM No Fault (+) Contactor Voltage Sense #1 Fault
P0A1F_09_CM No Fault VT Sensor #2 Top/Bottom Wire Fault
P0A1F_10_CM No Fault VT Sensor #2 Pack Voltage Sense Line Fault
P0A1F_11_CM No Fault VT Sensor #2 Module Voltage Sense Line Fault
P0A1F_12_CM No Fault VT Sensor #2 Reference Wire Fault
P0A1F_13_CM No Fault VT Sensor #2 Internal Severe Fault
P0A1F_14_CM No Fault VT Sensor #2 Internal Minor Fault
P0A1F_15_CM No Fault VT Sensor #2 Communications Fault
P0A1F_17_CM No Fault VT Sensor #1 Top/Bottom Wire Fault
P0A1F_18_CM No Fault VT Sensor #1 Pack Voltage Sense Line Fault
P0A1F_19_CM No Fault VT Sensor #1 Module Voltage Sense Line Fault
P0A1F_20_CM No Fault VT Sensor #1 Reference Wire Fault
P0A1F_21_CM No Fault VT Sensor #1 Internal Severe Fault
P0A1F_22_CM No Fault VT Sensor #1 Internal Minor Fault
P0A1F_23_CM No Fault VT Sensor #1 Communications Fault
P0A1F_27_CM No Fault Module Voltage Out of Range Low
P0A1F_28_CM No Fault Module Voltage Out of Range High
P0A1F_30_CM No Fault Cell Failure
P0A1F_31_CM No Fault Battery Module Voltage Deviation Fault
R_LEAKN 390005 Ω Leakage Resistance (Bus -)
R_LEAKP 390005 Ω Leakage Resistance (Bus +)
TRAC_M_AMP 1.43 Amper Traction Main Current
V_PACK 307.19 Volt Battery Pack Voltage
AVG_SOC 36.98 % Average State of Charge
AVG_TEMP 27 °C Average Temperature
BATPAC_STAT Pack OK Battery Pack Integrity
BSOC 38.60 % Battery Pack State of Charge (SOC)
CCNT_BCM 0 Continuous Codes
DELT_SOC 3.00 % Maximum Difference in State of Charge
DELT_TEMP 1 °C Maximum Difference in Temperature
DEL_MOD_V 0.00 Volt Delta Module Voltage
DISCHRG_LMT 29750 Watt Discharge Power Limit
EVAP_TEMP 24 °C evaporator temperature
HEV_VEHSTAT Normal HEV Vehicle Status
MAX_CHRG 22000 Watt Maximum Charge Power Limit
MAX_SOC 38.98 % Maximum State of Charge
MAX_TEMP 27 °C Maximum Temperature
MIN_SOC 35.98 % Minimum State of Charge
MIN_TEMP 26 °C Minimum Temperature
accent2010
Feb 22, 2021 03:15 PM
Travis Beck
Nov 6, 2019 08:12 PM
fired_up
Jan 5, 2017 11:58 PM
