Journalism & The Media Television, radio, movies, newspapers, magazines, the Internet and more.
BMW: HSD vs two-mode
Old Feb 16, 2009 | 10:34 AM
bwilson4web's Avatar
Engineering first
Default BMW: HSD vs two-mode
http://www.motorauthority.com/bmw-co...ve-hybrid.html
[quote]. . .
Conventional hybrid systems allow efficient motoring only in relatively small or medium-sized vehicles at relatively low speeds. This is because most of the power coming from the combustion engine has to be conveyed most of the time via the electrical path of the transmission and because of the use of a high level of electric power. A car with enhanced dynamics, performance and running speeds would therefore require a larger combustion engine calling for less efficient, larger and heavier electric motors.
. . . [quote]
First some facts and data about the current Prius transaxle:
  • 28% takes the electrical path
  • 95%*95% = 90% energy efficiency generator-to-motor
  • 28%*10% = 2.8% energy lost over electrical path
To put this in perspective, this is functionally equal to the energy loss of one additional gear stage.
In the power split drive mode, also referred to as the output branched concept, one of the two electric motors acts as a generator, converting some of the engine's power into electrical current subsequently fed to the battery or the second electric motor. The second electric motor then converts such power coming from the first electric motor or from the battery back into mechanical power for the output drive shaft on the transmission.
This description is inaccurate as MG1 power flows directly to or from MG2. However, it is an accurate of what the Volt, a series hybrid, will do. But the Volt carries a substantial amount of power in the battery.
As long as BMW continues to believe this is the case, they will be disappointed by real world test results. In fact, it only takes a simple scan of existing HSD hybrids to understand how badly BMW has failed to understand the technology:
  • 289 hp - gas engine
  • 221 hp - motor power
  • 5,220 lbs - curb weight
So <ssssuuussshhhhhh> we don't want BMW to wake up and realize they may have published a false analysis of the Toyota HSD system.
Bob Wilson
bwilson4web
General Motors Corporation
Nov 26, 2009 10:19 AM
bwilson4web
Jun 28, 2007 02:54 PM
bwilson4web
May 21, 2007 07:22 AM
Adam_HybridCivic
Dec 16, 2005 09:17 PM
