Blue LED interior trim kit
Old Apr 10, 2006 | 08:31 AM
mmrmnhrm's Avatar
Wo ai Zheng!
Default Blue LED interior trim kit
Anybody out there splurge for this? Not on the Honda website anymore, but it did sound at least a little interesting.
Old Apr 10, 2006 | 05:43 PM
Kintak's Avatar
Default Re: Blue LED interior trim kit
I know somebody said they put a piece of colour gel (the stuff used for stage lighting) inside the dome light cover as a cheap alternative.
Old Apr 10, 2006 | 07:16 PM
BigPanda's Avatar
Yup, I bought in. It's actually pretty cool looking. But that's it. Cool looking. If you have the extra dough and are into really techy stuff you'd probably dig it.
Old Apr 10, 2006 | 08:22 PM
mmrmnhrm's Avatar
Wo ai Zheng!
Have any pics you could post? I passed on it simply because the description was so incredibly vague.
Old Apr 11, 2006 | 01:56 PM
mexiken's Avatar
I did it as well, and I agree with Panda. Its cool, but thats about all its good for. Looks really cool at night though....
Old Apr 11, 2006 | 06:09 PM
JimHolmgren's Avatar
Anyone self-install it? It's not too expensive, if you can do-it-yourself.
Old Apr 11, 2006 | 06:34 PM
Z71's Avatar
Z71
Just had mine installed by the dealer today. Negotiated for $190 installed since was screwed with $550 alarm I did not want or need. Cool at night but you can spend your money better elsewhere.
Rick
Old Apr 12, 2006 | 06:47 AM
blinkard's Avatar
I thought about it, but then I read the installation instructions at handa-accessories.com and it says you have to sacrifice the little storage cubbyhole on the left side of the dash for the on/off switch.
I just thought it would be nice if it would come on when you open the doors, so you could see the footwell when you're sitting down.
Old Apr 12, 2006 | 03:18 PM
falconers's Avatar
I installed this weekend. I got from H & A Accessories quite cheap. It isn't too tough to install. Yes you do lose the pocket to the left of the steering wheel where the switches go. Took me a couple hours taking my time.
You pop off a few dashboard panels and route the wiring harness. Probably the hardest thing is the routing of the wire based on looking at the instructions. That isn't too bad. Just find the big fat main wirning harness & follow that. Then pop everything out the middle console & then the end one back around and out from under the glove box.
Overall, it looks nice at night. Not too bright. Just a soft LED glow under the dash for the driver & front passenger & in the middle pocket area. Basically, 3 small LED light just mount onto the dash board.
I bought this when I bought the mud flaps which were VERY easy to install. I do recommend that you jack up the back end a bit to make access easier to put the screws in for the back ones. Easier than removing the tires & makes things a lot quicker & less frustrating. Also, it's easiest if you break the pin attaching the deflector with a pair of pliers rather than trying to remove it.
The front ones are simplistic to install.
Old Apr 12, 2006 | 04:16 PM
mexiken's Avatar
I don't remember losing it, I still have it as far as I know, Paola is getting her oil changed, so I will look after I get it back.
