Hybrid & Related News New cars, press releases, articles and more. Reply only. Have news?
Toyota aiming to make hybrid systems cheaper
Old Nov 16, 2005 | 08:15 AM
lkewin's Avatar
Owner of '06 HCH #7264
Default Toyota aiming to make hybrid systems cheaper
Toyota Motor Corp. could begin using a cheaper and smaller hybrid system as of 2008, a spokesman told the Asahi newspaper, which also reported that the company plans to more than double production of the fuel-sipping vehicles by then to 600,000 units a year.Since rolling out the world’s first gasoline-electric hybrid car in 1997, Toyota has improved the powertrain with a second-generation system it calls THS II, which powers the remodeled Prius and Lexus RX400h SUV, among others.
http://msnbc.msn.com/id/10067373/
Old Nov 16, 2005 | 11:13 AM
xcel's Avatar
Default Re: Toyota aiming to make hybrid systems cheaper
Hi Lkewin:
___Not only do I hope Toyota has succeeded in shrinking AND lowering the cost of THS while at the same time adding more power, I hope the new Camry Hybrid is equipped with the Third Gen system! If the above is true, they could leave the Prius’ 1.5L as the base propulsion and the FE of another 350 #’s would only knock her back by maybe 3 - 4 mpg. A Camry Hybrid with the third gen THS would be worth 56 - 57 City/45 - 46 highway. And at a lower cost then the Prius II was manufactured? That would wake up some auto exec’s from Detroit, Europe, and even Japan now wouldn’t it
___Good Luck
___Wayne R. Gerdes
Old Nov 16, 2005 | 12:00 PM
EricGo's Avatar
The article I read said HSD III circa 2008, yet the Camry HSD is expected next year. You may have to make do with 50 city if you cannot wait.
Old Nov 16, 2005 | 12:08 PM
AZCivic's Avatar
Conservative Socialist
What's the aerodynamic profile of the Camry versus the Prius? I would suspect it has both additional frontal area as well as a higher cd. Also, the Camry Hybrid will likely wear larger, higher drag tires than the Prius. I'm not sure they'd be able to make 50mpg, but I suppose we'll find out soon enough.
Old Nov 16, 2005 | 06:02 PM
xcel's Avatar
Hi AZCivic:
___You really have to get out and drive an Escape HEV and a Prius after proper setup. Both will shock you as to what they are worth in their particular extreme realms.
___EricGo, I know about the 08 MY stuff … The wish part is that some of the THS parts will supposedly be American sourced. Guess which Toyota hybrid will be American sourced next year? Wishful thinking of course
___Good Luck
___Wayne R. Gerdes
haroldo
Feb 19, 2010 07:35 AM
fernando_g
Hydrogen Vehicles
18
May 18, 2009 05:15 PM
Jason
Aug 12, 2007 08:50 PM
felixdacat
Dec 10, 2006 04:23 PM
mexiken
Nov 13, 2006 10:51 PM
