Aiming/Adjusting Headlight Clarification
Old Dec 4, 2006 | 04:47 PM
felixdacat's Avatar
Pimpin ain't easy!
Default Aiming/Adjusting Headlight Clarification
Hey everyone,
Just for clarification, to adjust the headlights (up/down) i put a long philips screw driver in the hole w/the up down label correct? But upon doing this i don't see a screw there for the screwdriver. BUT this is a bolt w/teeth on it. Now is that where the philips screw driver goes?
Old Dec 5, 2006 | 09:26 AM
BlueVFRank's Avatar
Default Re: Aiming/Adjusting Headlight Clarification
I haven't looked into it on my HCH2, but the way you describe it it's the same as on my Honda Interceptor. Can be a real pain in the #$#$
Old Dec 6, 2006 | 12:54 PM
ppgroup's Avatar
If you lights are not adjusted correctly, take it to Honda - your car has a warranty, doesn't it?
Old Dec 10, 2006 | 04:23 PM
mexiken's Avatar
Felix,
Here is the correct way to do it. Or at least the way I did it. That wheel with teeth has a bolt. Make suer its night out, turn on your lights, preferably against a wall. Turn the bolt with a wrench or socket, whatever you choose, and you will see the lights either lower or raise (can't remember which way does what). I lowered mine, I actually like them much more lowered.
deprotinator
Jan 3, 2012 04:16 PM
DJWorm
Nov 27, 2009 06:16 AM
SDcomuter
Mar 31, 2008 12:33 PM
mexiken
Nov 13, 2006 10:51 PM
lkewin
Hybrid & Related News
Nov 16, 2005 06:02 PM
