Electric-only acceleration in the Insight
Old Oct 4, 2009 | 01:54 AM
weyus's Avatar
Default Electric-only acceleration in the Insight
So, I'm curious. The Insight also uses IMA, Honda's hybrid powertrain system. However, I'm reading that the Insight is electric-only under 30 mph. What did Honda tweak to allow for the IMA to behave this way, different from a Civic or Accord? Is it just that the Insight makes so much less demand of the engine that this is possible?
Thanks,
Wes
Old Oct 4, 2009 | 08:55 AM
Mendel Leisk's Avatar
Default Re: Electric-only acceleration in the Insight
Originally Posted by weyus
<snip>However, I'm reading that the Insight is electric-only under 30 mph.<snip>
I doubt very much that the Insight II behaves much differently than the HCHII, as far as the conditions under which the car will use the electric motor only. I can guarantee it is not electric motor-only under 30 mph.
Electric-only propulsion with the HCHII (and Insight II, I assume) will happen typically on level or downhill roads, with very light load conditions, fully warmed engine and sufficient IMA battery state-of-charge. I don't think there's a precise cut-off speed for electric-only, but it gets progressively harder to achieve at higher speeds. You need a very light touch on the gas: just enough to maintain momentum.
Electric-only tends to be very fleeting, and that's likely for the best: it eats the IMA battery charge fairly quickly.
Old Oct 4, 2009 | 08:58 AM
mrkcohen's Avatar
Moderator
I'm kinda curious where you're reading the Insight is electric only under 30.
Because it just ain't so....
RetepSnikrep
Honda Insight
Feb 21, 2015 09:59 PM
GONESKIING
Jun 15, 2007 01:16 PM
Hovercar
Honda Insight
Jun 7, 2006 04:07 AM
Inigo Montoya
Jan 24, 2006 02:03 PM
