My 2006 insight is down
Old Jun 16, 2006 | 10:41 PM
cattygurl's Avatar
Unhappy My 2006 insight is down
Started with the engine sounding like crap and the IMA being down.
Something majorly went wrong with my car, the dealership is not quite sure what it is yet, but need special equipment sent to disassemble the transmission. Apparently, this is the 2nd 2006 Insight with the same exact problem- IMA down under 3k miles on the odometer. The other insight with the same issue is in NY, according to American Honda. They need to get into the sensors in the transmission before they can further disagnose the issue, according to American Honda. Hence- the special equipment, since the tranny in insights have a strong magnet that requires special tool from Japan.
I'm looking at 2-3 weeks for the repair, possibly longer. They need to wait for the special equipment from American Honda, then diagnose, wait for parts, etc. The manager said he was hoping to get the car back ASAP, but couldn't guarantee a time frame. Thankfully, I will be getting a free rental out of this. I hope this is not a lemon... I miss my insight!
I don't have much details yet, but there are 6 codes, all IMA related. I'll be getting the exact codes...
I'll put more info down as I see it.
Old Jun 17, 2006 | 08:37 AM
Delta Flyer's Avatar
Banned
Default Re: My 2006 insight is down
cattygurl,
I'm sorry you are going thru this.
The silver lining is you definitely have warranty protection - keep it documented.
I would not be suprized if they replace the entire IMA unit to make sure it's resolved.
After all, they don't want to scare away people from hybrids....
Old Jun 18, 2006 | 06:05 AM
SretiCentV's Avatar
I sympathize with that catty. I bought a used insight (05 low miles) and its been in the shop about 50% of the time. My HCH ~20k miles has run beautifully since the day I drove it off the lot with only maintenance having been performed.
Nonetheless, your problem is like a 1/10,000 shot.
Old Jun 19, 2006 | 08:19 AM
LoudMusic's Avatar
Just getting rolling ...
Did they give you a gas card to go with your rental?
Old Jun 19, 2006 | 12:02 PM
Hovercar's Avatar
Sorry to hear about your trouble - I know I would be devastated. We'll hope for an early return and trouble-free miles for the future for you. John
Old Jun 22, 2006 | 06:58 PM
rigger's Avatar
now Insight, had an HCH
Update Yet?
Old Jun 27, 2006 | 01:56 PM
cattygurl's Avatar
Okay - my car is back, finally! And I'm going to post what went down with the vehicle. I was pissed off that the tow truck guy left grease handprints over the upholstery and scratched the bumper. Mad I'm dealing with the owner to get my bumper repainted and pay me for the $$$ I paid to clean my upholstery.
Sigh.
Okay, here's the detail of what went wrong:
Initial fail code: P1644/P1600 IMA MOTFA Signal Failure/IMA System Malfunction
Replaced MCM Control Module, cleared code and tested. Recoded with code P1565. Motor Commutation Signal problem. Found weak signal from motor commutation sensors located in engine. Removed transmission to replace 3 sensors, cleared codes, operation as normal. Due to signal failure, vehicle was unable to recharge IMA batteries which caused the IMA failure.
My car does drive fine, but I hear a high pitched whirring (almost like a belt running) noise when the engine shuts off as I'm coming to a stop. also, the engine shuts off @ 10mph, rather than after a complete stop. Is this normal? Thanks!
Old Jun 27, 2006 | 02:39 PM
GeekGal's Avatar
If I remember this thread correctly, you really didn't have much time in your Insight before things started going south.
The high pitched whirring is probably your electric motor. Smarter folks than me can explain what it's doing, but that's the only sound my hybrid makes when its ICE turns off at a stop or low speeds.
If the Insight is at all like the FEH, the having the ICE go off at 10mph is also perfectly normal and desirable. Delta Flyer or one of the other Insight folks here can provide better feedback, but I'd say your Insight may finally be behaving like an honest-to-goodness healthy hybrid now!
Old Jun 27, 2006 | 02:52 PM
nash's Avatar
Congratulations on getting your Insight back!
I'm pretty sure the "whirring" noise is the electric motor aiding your stop by "regen" (ie: charging the IMA battery). My TCH makes a high pitched whirring noise when I brake and the ICE usually stops if under 43mph when costing or braking.
Old Jun 27, 2006 | 02:53 PM
cattygurl's Avatar
Yup, my car was almost new. The odometer was around 2700 miles, I belive, when my IMA went down. Hopefully, this fix was a one-time deal, and I'll have a car that will last me a long, long time.
Man, this car has been an ordeal- from the dealer messing with me, the tow truck messing things up- to the IMA going down. I've gotta say though, that it's been worth it. I got 82.5mpg last night when I went out to eat.
