XM option cost
Old Jan 7, 2006 | 10:39 AM
bfranci's Avatar
Default XM option cost
I checked the Honda website and the materials cost for the XM option is around $440 or so (not counting install). The dealer I asked quoted me $950 though! I can't phathom that the install costs $500...
Anyone else out there get the XM option and can relate how much it cost?
Brad
Old Jan 7, 2006 | 11:23 AM
dshelman's Avatar
Default Re: XM option cost
I can believe it.... The directions show them tearing half the car apart to put that in. They should have at least pre-wired it, and then it realy would have been XM-Ready. For about 50 bucks, you can do it yourself with a Roadie 2.
Hope this helps,
Don
Old Jan 7, 2006 | 12:14 PM
tigerhonaker's Avatar
G.H. Contributor
Lightbulb Re: XM option cost
Brad
Hi Brad;
Just looked up this Honda Install for X/M sat. radio for you:
This will let you see the reason for the high labor cost, it's real involved.
http://www.handaaccessories.com/civi...ichybridxm.pdf
HTH;
Terry
BTW: I did order it and I am paying for the install at the Honda Dealer. The reason is I want it to be covered by the Honda New Factory Warranty. If the Dealer does the Install at the time you purchase your HCH ll then you have the X/M Sat. Radio covered by Honda.
Old Jan 7, 2006 | 03:58 PM
bar10dah's Avatar
For anyone else considering XM but doesn't want to fork out the money for a $900 factory install: The Roady2 is $29 right now. No installation. We have it in our Escape. Attached the unit right below the radio. Plugged power supply into the switched cigarette lighter so it turns on and off with the truck. And, before I ran the antenna under the trim and out the back window, the XM worked just fine with the antenna sitting in the middle of the dash board. It was just secured with a zip tie to the defroster vent.
The best part? If you decide to switch vehicles later (trading in, selling, or just using a different car for a road trip) the XM can be moved to the other vehicle in a matter of minutes!
And, if you park the vehicle close enough to your home stereo, you can pipe in XM music to your house! Or, office.
Old Jan 7, 2006 | 09:52 PM
AZMerf's Avatar
This "XM Ready" is really a big joke. At first I was excited and was going to have it installed ... not for $1K though and then $13 a month. They are kidding themselves.
Old Jan 7, 2006 | 11:27 PM
mochisushi's Avatar
4 Kids-Can't afford gas!
My dealer is quoting $750 for install. I bought the Roady XT from Best Buy. Had a 10% off coupon, plus a $30 rebate, so it only cost me $42. Since the HCH didn't come in on 1/02 as planned, I stuck it in the Sub for now. Took about 15 minutes to install (used the vent mount). If I can convince my dealer to give me the XM in the HCH for messing up the order, I'll keep it in the Sub, otherwise it will move to the HCH when it arrive.
Old Jan 8, 2006 | 04:37 AM
springkitten's Avatar
My HCH II came preinstalled with XM Radio - I guess the person who originally ordered the car didn't take it - but the dealer didn't charge me extra for it !! I also got 3 months free access. !!
Old Jan 8, 2006 | 10:44 AM
G.H. Contributor
Question Re: XM option cost
Hello Michelle (Kitten) ;
Boy did you come out smelling like a rose on that. So, you got the x/m sat. option installed on your car and at (No-Cost) to you period. That is like so very CooL. It runs with Labor somewhere around the $800.00-900.00 range installed. They (Dealer) has to remove half the car to do the install.
Say how does the antenna look up on the windshield? Is it mounted at the top, right hand corner of the wind shield? Did they put a piece of Tape on the outside of the windshield to cover the position of the inside antenna mount? Please, more info on how it looks, The Antennae:
I have it ordered on mine and I am concerned about how they do the antenna mount.
Thanks;
Terry
Old Jan 8, 2006 | 01:15 PM
xcel's Avatar
Old Jan 8, 2006 | 01:33 PM
kenny's Avatar
Don, is THIS what you are talking about?
http://www.xmradio.com/roady2/index.jsp
They spell it Roady2, is this the same thing?
Also the XT:
http://www.xmradio.com/roadyxt/
Hope this helps,
Don
