What PSI does everyone run their tires at ????
Old Mar 9, 2006 | 01:58 PM
kmh3's Avatar
Default Re: What PSI does everyone run their tires at ????
Originally Posted by mexiken
km,
Was this is another thread ???? Do you remember which one ????
https://www.greenhybrid.com/discuss/...lage.6066.html
- Kurt
Old Mar 9, 2006 | 02:00 PM
mexiken's Avatar
Thanks Kurt !!!!
Old Mar 9, 2006 | 02:13 PM
Tim's Avatar
Tim
Enchanter, Enthusiast
Originally Posted by Sledge
I filled my tires to 35 psi when it was 24F outside. Have no idea what they are now that it's 50F+
I've heard it in other threads that it's 1 psi per 10 degrees. So I'd guess around 38.
Old Mar 9, 2006 | 02:32 PM
Sledge's Avatar
YA RLY.
I'm cool with that
Old Mar 9, 2006 | 02:34 PM
zimbop's Avatar
40psi. Here's a tip, I used my labelmaker to make a black-on-clear label, which i put on the inside of the windshield where they normally put the oil change reminder. It says "Tires @ 40 PSI please." That way, when I forget to remind them I like my tires the way they are, they might find the message on their own when they go to update the reminder.
Old Mar 9, 2006 | 02:47 PM
tanstaafl14's Avatar
Just bumped the tires on the new HCH up to 38. If the ride is still good, I'll take them up to 40 (which is where I keep them on the '05).
Old Mar 9, 2006 | 02:58 PM
Hot_Georgia_2004's Avatar
I've ran my Dunlops @ 51PSI since new.
Hard as rock. Gotta love it!
Old Mar 9, 2006 | 03:21 PM
Wangofree's Avatar
50.5 psi with a sidewall max of 51. Ditto on HG's comment.
Old Mar 9, 2006 | 05:27 PM
masgian's Avatar
How do you guys check the pressure so accurately? Looks like the "bye eye" method I was using is not good anymore
And how do you adjust the pressure? Do you carry a portable compressor?
Old Mar 9, 2006 | 05:55 PM
tigerhonaker's Avatar
G.H. Contributor
Lightbulb Re: What PSI does everyone run their tires at ????
I have the Dunlops on there, and I keep them at 44 PSI (the max on the side of the tire). What does everyone else run their tires at ???? Can I go higher ????
Hi mexiken,
Exactly the "Same-As-You." 44 PSI All-4
When I picked the HCH II up from the dealer last Saturday they had already put 44 PSI in all 4-Tires.
Roads here are Pretty Smooth so No-Problem with Pot Holes Etc.
Regards,
Terry
