Trunk Deck Spoiler good/bad for drag?
Old Mar 13, 2006 | 10:56 AM
tanstaafl14's Avatar
Default Re: Trunk Deck Spoiler good/bad for drag?
Hybrids are engineered from the ground up for maximum FE. Honda wouldn't have put that spoiler (or anything else) on if it decreased FE by any amount whatever.
Old Mar 13, 2006 | 11:33 AM
Casper49's Avatar
I believe mwong99 is on the right path.
In pickups (according to Mythbusters), it gets better mileage and less drag with the tail gate up - because it reduces turbulant air.
It probably helps on HCH-II, but I tend to think that it was for visually distinguishing HCH versus normal Civic.
Old Mar 13, 2006 | 11:42 AM
hweldon's Avatar
I think its like a Formula 1 car. It produces enormous downforce. Which means you don't have to lift when negotiating turns.
"HE HE HE"
Howard
Old Mar 13, 2006 | 11:59 AM
ElanC's Avatar
Honda's marketing strategy seems to be NOT to make a distinction between the hybrid and the regular Civic. If they chose otherwise they could have made the HCH much more distinct.
The spoiler is meant to increase FE. I have no doubt about that. For comparison look at the Prius. The older model had a spoiler. On the newer model they changed the design so that the tail end is very high and drops straight down. So there's no longer a need for a spoiler. Although it may be counter-intuitive, it seems that a higher tail with a straight cutoff is aerodynamically better, and a spoiler helps accomplish that.
geek
Mar 14, 2009 07:11 PM
leepark
Nov 28, 2007 07:33 AM
shoebox303
Nov 8, 2007 08:26 AM
shoebox303
Nov 7, 2007 11:33 AM
shoebox303
Oct 26, 2006 07:10 AM
