Routing wires through the firewall
Old Dec 27, 2009 | 11:44 AM
raidfibre's Avatar
Default Routing wires through the firewall
I'm installing a small powered subwoofer in the trunk of my 2007 HCH.
I got as far as routing the wires through the back seat. (1" spade bit through the IMA battery)
Now I'm trying to figure out where to push the power wires through the firewall to attach to the 12v battery. I looked around with a flashlight but I couldn't find any grommets that seemed to be accessible from the inside to the engine compartment. If you've done this before, can you tell me where to look? I'd very much prefer to go through on the left side of the car so I don't have to run the wires across the top or back of the engine to reach the battery.
Thanks.
Old Dec 28, 2009 | 02:52 AM
ovals49's Avatar
Default Re: Routing wires through the firewall
If you remove the driver's side front plastic wheel well liner and follow the hood release cable housing that should be a pretty good route, at least it was on my 2005.
I hope you're joking about the spade bit in the rear. If you remove the rear seat you should be able to find a small hole in the rear bulkhead where the wire can be snaked through.
Old Dec 28, 2009 | 04:03 PM
raidfibre's Avatar
Yeah I was just joking.. I would have had a hard time with a spade bit.
I found a pretty good place along the right side behind the back seat. Thanks for the tip with the wheel well. I had a hard time getting the wheel well out when I put in my HID lights so I'm not sure if I want to do that again but it's probably the location that will give the cleanest install.
I see you're in Cape Cod. I live in Brookline so maybe when it gets warm again I'll pull the wheel off and see if I can make it work.
Thanks for the tip.
Old Dec 28, 2009 | 04:05 PM
raidfibre's Avatar
I meant the left side. The wire's going to go up the left side all the way to the battery.
Old Feb 3, 2012 | 06:26 PM
cutlergolf's Avatar
I have a 2010 Insight check out this video.
http://www.youtube.com/watch?v=dHmEr...bNpnrEBsiqg_em
Old Feb 4, 2012 | 07:55 AM
There are spare places to hook up in the fuse box inside the cab! H
Old Feb 4, 2012 | 07:57 AM
Hook into the fuse box spare locations. H
zosim
Jul 25, 2009 07:52 AM
holicow
Apr 22, 2008 07:13 PM
highflyer_i469
Jul 17, 2007 02:40 PM
feinstei
Jun 11, 2006 06:05 PM
n1ywb
Apr 8, 2005 01:41 PM
