Rear Drum Brakes
Old 07-31-2008, 01:12 PM
ronnie38's Avatar
Default Rear Drum Brakes
I'm still waiting for my car now it's will be next week. So I continued to study the design, the 2008 still has rear drum brakes.The last car I had with rear drums was an Audi 4000 in the 80's. Now with re-gen braking Honda must have determined that disk brakes cost more and therefore not needed, but disk brakes are about 40% less weight then drums. So should I plan on replacing the rear brakes along with LED lights, nitrogen air in the tires and 0 weight oil to increase my FE
Old 07-31-2008, 05:21 PM
GardenWeasel's Avatar
Default Re: Rear Drum Brakes
Nah! You have to create a baseline first to see what the changes do for you. Only one I like of your list is the 0W20 (at the first oil change - no need to do it early). Best wishes...
Old 07-31-2008, 05:48 PM
kristian's Avatar
Brakes? What are those? I hardly use mine anymore....or at least the friction ones.
Old 07-31-2008, 06:24 PM
mdarmistead's Avatar
Hybrid Evangelist
Thumbs down Re: Rear Drum Brakes
Read up on nitrogen in your tires.... big scam.
http://www.straightdope.com/columns/070216.html
http://www.nytimes.com/2008/03/09/au...es/09MOTO.html
http://blogs.consumerreports.org/car...nitrogen-.html
By and large, the vast majority of sites out there singing the praises of nitrogen filled tires are trying to sell you the product/service.
Air = 78% Nitrogen 21% Oxygen 1% other gases.
Old 07-31-2008, 08:37 PM
holicow's Avatar
If discs offered an efficiency advantage over drums on the rear, Honda would have used them.
I am not sure the weight difference is as much as you state. Anyway, the regenerative braking function does a lot of the mild work (through the front wheel, of course).
Old 07-31-2008, 10:42 PM
bigbrian1980's Avatar
Banned
I think Honda did that for safety. Do you think it will fit if you replace it with disk brakes?
________________
Must Read: Autopartswarehouse
Old 08-01-2008, 06:01 AM
raidfibre's Avatar
The car has drum brakes on the rear for a couple of reasons:
Disk brakes are more prone to dragging than drum brakes.
You have regenerative braking.
Most of the braking force is needed on the front wheels.
prototype3a
11-19-2014 04:52 AM
thanksjc
06-11-2013 05:48 AM
HyCAMBill
07-28-2012 06:52 AM
stevedebi
06-18-2008 03:50 PM
fredo48
11-08-2006 02:36 PM
Quick Reply: Rear Drum Brakes
