Problems with my 03 HCH can someone help
Hi I had a problem with my 2003 HCH this morning, I went to start it and it was like a dead battery when i turned the key all the dash lights dimmed and did not want to crank over. after trying a few times it finally turned over (slowly) and then started up. when it was running the battery light was on almost all the dash indicator lights were on (SRS,MAINT,ENGINE,Ect..) when i put a volt meter across the battery i was reading only 8.5 volts. i stepped on the gas pedal and it reved once then stalled and i could not crank it at all. I jump started the car with a booster pack on the battery and it started with no problem all my indicator lights went out except my SRS light and the car is charging at 13.5 volts now. and the car starts and runs fine now. could all this be from just a simple dead battery? I ran the codes and my scanner came up with 1790 and 1793 any ideas? thanks for any help in advance
Re: Problems with my 03 HCH can someone help
I have no idea what the problem might be but here is a list of Honda OBD-II Trouble Codes.
lensterman
Toyota Highlander Hybrid
08-07-2010 11:33 AM
hch2007owner
01-23-2009 10:11 AM
