Parking
Old May 22, 2006 | 08:06 PM
Mr. Kite's Avatar
Default Re: Parking
Originally Posted by Kintak
I've always been curious about this: if you're not parking on a hill, why set the parking brake? I almost never use the parking brake. Is there some mechanical reason to use it, or something else? Thanks.
According to the manual:
If your vehicle has an automatic transmission, set the parking brake before you put the transmission in Park. This keeps the vehicle from moving and putting pressure on the parking mechanism in the transmission.
I guess this is a good idea, but it is a habit that I have not gotten into yet.
Old May 22, 2006 | 08:42 PM
ElanC's Avatar
Default Re: Parking
The last thing I do is take my foot off the brake. So it doesn't matter if I shift into Park first or engage the parking brake first.
Old May 22, 2006 | 09:40 PM
mmrmnhrm's Avatar
Wo ai Zheng!
Default Re: Parking
Not true in the 06 HCH. Shifting to park will cause the ICE to re-engage. That's the whole thing we're trying to avoid here.
Old May 22, 2006 | 09:54 PM
ElanC's Avatar
Default Re: Parking
I wrote about the sequence of shifting the transmission to park before or after activating the parking brake, as was quoted from the owner's manual. It has nothing to do with re-engaging the ICE.
Will pulling the parking brake handle first prevent the ICE from re-engaging? No. So what's not true?
Old May 23, 2006 | 03:58 AM
gchu's Avatar
Default Re: Parking
One down side to turning off the car before you put it into park is that the driver side door does not unlock "automatically" - you would need to manually unlock it before you can open the door.
Sure this is a very minor thing, but one of my pet peeves about the Civic is that the doors don't unlock when you pull the inside door release. I can understand about the rear seats for kids, but for the front driver and passenger?!?!
Old May 23, 2006 | 08:12 PM
chesleyn's Avatar
Default Re: Parking
There are multiple settings for the door unlocks. Change yours.
Old May 24, 2006 | 04:35 AM
gchu's Avatar
Default Re: Parking
I did change my settings so it unlocks when I put it into park. Unfortunately, if you turn off the car before you put it into park (to avoid restarting the car from autostop), it does not unlock when you put it into park.
I actually do not like the way it works on the Civic anyway as I do not want the doors to unlock unless the door release handle is pulled. This way, I don't have to be concerned about having someone jump into the car when I park it. Just a personal preference. I'm sure I am in the minority that are concerned about that level of safety.
Old May 24, 2006 | 08:21 AM
mmrmnhrm's Avatar
Wo ai Zheng!
Default Re: Parking
I had the "pull handle to unlock door" in my old Sable, and by the feel of it, I think it required a mechanical linkage, and wasn't handled by the power lock mechanism.
ally3223
Apr 24, 2006 04:53 PM
heavenleigh
Oct 17, 2005 07:43 PM
Outlooking
Sep 20, 2005 10:01 PM
ericbecky
Honda Insight
Aug 16, 2004 09:04 AM
ericbecky
Honda Insight
Apr 17, 2004 06:27 PM
