One Touch Window
Old May 12, 2006 | 01:12 PM
dburanich's Avatar
Default One Touch Window
Is anyone else having a problem with their drivers side one touch window on the HCH II. I seem to be having the hardest time if I only want it to open an inch or two. It seems to have a mind of its own and goes all the way down almost every time.
Old May 12, 2006 | 01:18 PM
geeckk's Avatar
Default Re: One Touch Window
Originally Posted by dburanich
...It seems to have a mind of its own and goes all the way down almost every time.
Mind of it's own? Are you having a problem even when you don't press past the "click"?
Every time I open the window, I press down too hard past the click and it starts going all the way down - but that is my own fault
I've got to learn to press the button without so much force!
Old May 12, 2006 | 04:03 PM
06 HCH in Georgetown TX's Avatar
06 HCH Opal Blue Pearl
Slight push (or pull) takes it down and up till you let go. Push a little harder, past the not-so-noticable click, and it will go all the way down. Same for going up. Takes a bit to get the feel.
Bob
Old May 13, 2006 | 07:42 AM
dburanich's Avatar
It seems like no matter how lightly I push the switch the window goes all the way down. Same thing going up. Based on what I'm hearing here, it sounds like I may have a bad switch. I do not feel a distinct click when depressing the switch.
Old May 13, 2006 | 02:32 PM
Donald's Avatar
MEAN TO BE GREEN ACTIVIST
I don't feet a click in my switch either. Sometimes just a real quick "very light" tap will move it just a bit. Other times, it goes all the way down. My guess is that it's a design flaw. Other cars that I've had have not been this "touchy".
Good luck,
Old May 14, 2006 | 12:20 AM
exbauer's Avatar
hmm...i don't really have this problem. i am able just to roll down the amount of window i need without having it go into auto mode. i guess you guys are a lot more harder on the switch. hahaha
Anahymbrid
May 20, 2007 09:22 AM
econoline
Apr 13, 2007 08:13 PM
dogzen
Jan 20, 2007 09:24 AM
pquig
Jul 7, 2006 08:44 PM
manchild
Mar 10, 2006 08:01 PM
