Need help 07 Ima and battery light
Old Jan 19, 2016 | 01:40 PM
  #81
Default Re: Need help 07 Ima and battery light
Good luck!
Steve
Old Jan 19, 2016 | 01:41 PM
  #82
You need one per subpack, so 11. This will enable you to discharge them all in the same 24 hr period.
Old Jan 22, 2016 | 03:08 PM
  #83
Ascension's Avatar
Hey Steve am I checking for the 6v with load or without? In other words when the battery connect with the bulb and it reaches 6v or when I disconnect the bulb and read 6v?
Old Jan 22, 2016 | 07:44 PM
  #84
check voltage with bulb attached and terminate when it hits 6V. ±0.5V is fine if you want a little wiggle room.
Old Feb 8, 2016 | 05:25 AM
  #85
hunter44102's Avatar
Steve how do you physically find the bad 'stick' if you know one is bad based on the orange connector.
For example, if B13-B4 is bad, is there a diagram to identify? do those sense wires have the same color when they measure the sticks?
thanks
Old Feb 8, 2016 | 07:30 AM
  #86
I mapped them out one time, but it's to my own numbering scheme... and finding that documentation would be a challenge.
Best way is to trace the wires. The colors are consistent from the plug to the coverplate, which takes you right to the stick.
stoshiro
Jan 12, 2021 03:11 PM
Bri
Dec 10, 2018 02:55 PM
drabood
Mar 15, 2016 09:44 PM
cak615
Oct 28, 2013 08:11 PM
SadCarTime
Jul 9, 2012 08:05 AM
