MPG - Calculated vs. computer?
Old Apr 12, 2006 | 12:19 PM
  #41
ElanC's Avatar
Default Re: MPG - Calculated vs. computer?
Originally Posted by mtrummel
I am confused. today I was cruising on a level freeway (CA) at 60 mph and the Instant MPG read 100 mpg for an extended time. I classify this as a defect of the on board calculator. Other times at lower speeds it does the same thing. Has any body else had this problem? does Honda comment?
How extended? Were you on a slight downhill slope? Perhaps traffic ahead of you was slowing down and you eased your foot off the pedal just a tiny bit?
Most likely what you saw was a glide with the valves shut and no fuel being consumed. The HCH will glide a long way this way because there is very little resistance from the engine compared to other cars where you have to feed fuel to the engine just to keep it from slowing down the car.
Whenever I see that Instant MPG reading at 100 I say - Oh what a feeling!
Old Apr 12, 2006 | 01:18 PM
  #42
mtrummel's Avatar
RVer Hybrid Toad
I was in cruise control and it lasted for at least 30 sec on a level freeway. I have also noted this at slow speeds(~30) for at least a couple of blocks. Perhaps your explanation is rite but I am familiar with "glides". I will try to check it next time I have a clear FW (not too often in CA)
Wolfy9048
Feb 28, 2012 08:27 AM
JoeFuture
Jan 29, 2007 04:34 PM
kenny
Jul 3, 2006 06:24 PM
jglaz
Oct 16, 2005 06:00 PM
zimbop
Aug 15, 2005 03:16 PM
