Higher Tire Pressures
Old Jul 4, 2006 | 08:23 PM
birchman2's Avatar
Default Higher Tire Pressures
Just curious what everyone has there tire pressure at. I have yet to add any air to mine but, am very hesistant to go over the recommended side wall pressure. Anyone on the list have a tire blow up because of to much pressure? Good experiences/bad experiences thoughts.
Old Jul 4, 2006 | 09:26 PM
mmrmnhrm's Avatar
Wo ai Zheng!
Default Re: Higher Tire Pressures
I think you'll find that everyone here either runs factory spec (35/32, I think), +5, or max sidewall (44 in my case). I doubt that anybody is running over sidewall, and if they are, it's not because we told them to.
Old Jul 4, 2006 | 09:29 PM
birchman2's Avatar
I remember reading about people running 50psi.
Old Jul 4, 2006 | 09:46 PM
gumby's Avatar
Energy Independence
Some tire sidewalls state up to 51psi max (especially on larger, wider tires - like those on many 17" rims).
My standard Dunlops are 44psi max. Whatever was put in at the dealership is what is in them, and I haven't checked yet (I've had the car only three days). I suspect they're at 32 or so, though.
Old Jul 4, 2006 | 10:21 PM
rysa4's Avatar
37 PSI.
Old Jul 4, 2006 | 10:29 PM
philmcneal's Avatar
04 prius 350,000km
max sidewall for me, I love the rolling feature that comes with it
Old Jul 4, 2006 | 10:41 PM
Casper49's Avatar
42 Front and Back for me.
Old Jul 4, 2006 | 11:16 PM
tbaleno's Avatar
60psi front and back on mine. Tires are rated at 51 btw. Standard 14" dunlop sp 20 FEs.
You are more likely to blow a tire with too low pressure than too high. I don't recomend going as high as I do unless your a fanatic, but the likelyhood of it blowing is less than someone running a tire at 10psi below recomended.
I've hit many a potholes without it blowing btw.
Old Jul 5, 2006 | 05:39 AM
zadscmc's Avatar
Have hybrid, will travel.
I run 45 front and back on my Bridgestones.
Old Jul 5, 2006 | 07:56 AM
HyChi's Avatar
44psi, sidewall max. I increased it slowly and didn't really notice any change.
