Help HCH problems
Old Jun 19, 2011 | 12:20 PM
Hondacivicman's Avatar
Default Help HCH problems
Help every morning when I go to start my car the battery is dead and the car has to be jumped. My brake, ABS and IMA lights come on after it's jumped but if I pull the fuse for the abs relay the lights shut off and don't come back on most of the time. Should I have the ABS checked or is it an issue with the IMA battery? My car does not have a check engine light nor is it throwing any codes. The car has 112000 on it and has a brand new optima battery. thank you for the help.
Old Jun 20, 2011 | 07:36 AM
Default Re: Help HCH problems
Sounds like you need a new 12V battery. Have you checked the voltage in the morning with a voltage meter? Voltage should be 12v or more after sitting over night! H
Old Jun 20, 2011 | 10:41 AM
The 12v battery is a brand new optima battery.
Old Jun 20, 2011 | 08:44 PM
Figured it out today. It is a short in my AC.
Old Jun 21, 2011 | 08:25 AM
That is good! What made you suspect the air condition had a short. That is a new one! H
Old Jun 21, 2011 | 08:33 AM
I did an amperage draw check with a multimeter. And pulled fuses till I found the the circuit that had the draw when I pulled the A/C compressor fuse it dropped to .02 A the draw when the fuse is in is 3.80 A. I was just being lazy and wanted to see what the suggestions were.
Old Jun 21, 2011 | 03:25 PM
Well thanks for the info. I wounder why it is drawing power when the ignition is off. Is the air conditioner still putting out when you replace the fuse? I have a 06 HCH2 has well and it has been a trouble free auto thus far! H
bbmotor
Jul 28, 2010 11:34 AM
Culpritgrl
Oct 9, 2009 05:59 AM
The Great Gazoo
Jun 9, 2008 12:37 PM
giantquesadilla
Aug 2, 2007 06:56 AM
