HCH II Fuel Filter?
Old May 18, 2009 | 03:16 PM
Tommy T's Avatar
Default HCH II Fuel Filter?
I've looked at several parts catalogs and never seen a listing for a replacement fuel filter (nor a PCV valve for that matter).
Do our cars have these common service parts, or are they rare/unique items that you can only get from the dealer?
Old May 19, 2009 | 07:57 AM
Mendel Leisk's Avatar
Default Re: HCH II Fuel Filter?
The simplest, safest, most practical approach is through your dealerships part department, both for performance and compatibility of fit.
Just doing a quick read through the Maintenance Main and Sub items, I don't see mention of either.
Looking through my Service Manual:
The fuel filter is a very specific item, in the fuel tank, requiring fuel tank removal for access. Definitely not something to do on a whim
The PCV valve looks to hide under the air intake system. I think it would be relatively straightforward and worthwhile to simply remove it, clean with carburetor cleaner and reinstall. There's really nothing to these: just a ball bearing with a backing spring in a plastic cylinder. If the tube isn't cracked a cleaning out of gum (if there is any) is as good as replacement.
Addendum:
I've not looked at the PCV valve on our current HCHII, but if it's anything like those I've seen in past cars, it's as I described above. In my experience the weak link was not so much the valve itself, but the grommet it pushed in to. It's rubber, and prone to drying/cracking, so that air can leak by. That item is more likely to need replacment.
Old May 30, 2009 | 03:50 PM
medicmike's Avatar
It's listed with the CVT tranny filter in the parts catalog (that is, nonexistent, for our purposes). No wonder I need a can of seafoam in the gas tank very so often.
GatorJ
Jun 6, 2014 12:03 PM
dgyimao
Dec 31, 2009 09:38 AM
bugs
May 26, 2009 12:05 AM
jscurrie
Jul 30, 2007 12:05 PM
cbxtc6
Jul 12, 2005 08:58 AM
