Engine Oiler System
Old Apr 19, 2008 | 04:20 PM
cheese4420's Avatar
Default Engine Oiler System
I was wondering how the engine oiling system worked on the Civics and also the Prius'. My question is that both engines shut off when not needed and then automatically start up again. If a majority of engine wear occurs during start-up, how does that affect the hybrid engines? The only way I see to avoid the lack of oil flow during start up is if there is an electric oil pump supplying the engine. If it's a standard mechanical driven pump, then I'm concerned about pre-mature engine wear due to lack of lubrication. Even if synthetic oil is used, I don't think it provides the same, or enough protection to prevent engine wear. If anyone can enlighten me on the engine oiling systems I would greatly appreciate it.
Old Apr 20, 2008 | 06:01 PM
pagemap's Avatar
Default Re: Engine Oiler System
The engine tolerances in Honda's 1.3L hybrid engine are very fine. Because of this, when the engine is off, the oil is held in suspension between the piston and cylinder walls.
Old Apr 24, 2008 | 09:41 PM
bullet4's Avatar
your correct about most wear at start up due to lack of oil.
but thats assuming the car sits long enough to drain all of the oil out of the oil jetting system and solenoids and cam journals and crank bearing journals. i dont know how long you sit in auto stop but i would guess that it would take about an hour to drain all the oil in the motor and oiling system back to the pan
Old Apr 24, 2008 | 10:13 PM
gumby's Avatar
Energy Independence
Cold start-up, yes - no oil in the moving parts IS a cause of long-term wear.
Warm start-up, not an issue - as oil is still mostly in-place, lubricating the moving parts (as bullet4 said).
cmobile
Mar 16, 2012 04:49 PM
Guss
Aug 7, 2009 01:09 PM
selia
Jul 15, 2007 08:23 AM
Paulgw
Nov 22, 2006 06:31 AM
fullofbeans
Sep 2, 2006 09:59 AM
