Engine oil heater
Old Feb 16, 2006 | 12:30 PM
RIHCH's Avatar
Default Re: Engine oil heater
Originally Posted by toast64
Has anyone installed an engine block heater in their HCH yet? Wondering how well it works. Does anyone know the wattage? I see that 600 watts is pretty typical for a block heater. The dealer wants $150, installed. I see you can get them on the web for about 50 bucks including shipping.
Yes Bill, I had the block heater installed at the dealership. The heater for my 04 HCH was $59.00 and another $60.00 to have it installed (which inclued new anti-freeze). I'm still not sure of the wattage used (I ordered a meter from Amazon , but I'm still waiting for it to arrive) but I use an outdoor timer and set it so its on for 5 hours. I so happy I had it installed. So far, my mileage hasn't dipped below 40 MPG and it would have been higher if not for the fact that I can't plug it in while I'm at work. I leave for work at 4 AM and lately the temps have varried from high teens to low 30's and with the 5 hour time limit on the heater, it starts up at 1,000 RPM and with mild heat (unlike when I leave work which starts up cold at 1,700 RPM).
Hope this helps
I will post my findings on wattage later.
Old Feb 16, 2006 | 12:51 PM
lkewin's Avatar
Owner of '06 HCH #7264
Originally Posted by lars-ss
Does anyone know if the '06 HCH has either a plastic dipstick tube or plastic oil pan, as both the above description advising the dipstick oil heater is Not for vehicles with plastic dipstick tube or plastic oil pan.
Old Feb 16, 2006 | 12:55 PM
lkewin's Avatar
Here is a link to a PDF of the install instruictions for a Honda 2006 Civic Hybrid Heater Block ~$ 50 on anythinghondaonline.com
http://www.anythinghondaonline.com/P...lockheater.pdf
Old Feb 16, 2006 | 06:54 PM
toast64's Avatar
Thanks, RIHCH!
That was exactly what I was looking for. I'll be interested in the wattage, but in the mean time I'm going to get one installed before it gets any colder here!
Appreciate the info!
Old Feb 16, 2006 | 07:03 PM
toast64's Avatar
Larry,
These dipstick oil heaters have been around for years, but I've never heard anything good about them. They heat up the oil, of course, but the block heaters heat the coolant, which is going to give you a much better chance at the car performing better when cold. I'm sure all of the systems that are controlling things like auto stop are deriving their info from the coolant temp. Mine will auto stop at 9 bars on the coolant guage, but won't seem to do it before that. Also, I've heard horror stories of the oil heaters shorting out. Not a good thing when it's submerged in oil. The ones I've seen are pretty low wattage, which is a good thing for protection but won't do much to solve the cold start issues. Just my opinion.
Old Mar 4, 2006 | 05:40 PM
toast64's Avatar
Default Re: Engine block heater
I got my block heater installed this week in my '06 HCH (now that winter is about over, duh! - but I've had the car for less than a month so...).
I put a meter on it and found out that it pulls 3.325 amps at 122 volts, or about 400 watts. In my area of the country I pay 8.61 cents per killowt-hour (or 8.61 cents for every 2.5 hours I run the heater), so I won't be saving a lot of money on gas with it, even if it gets me into auto stop quicker. I'd have to save a gallon of gas at $2.30/gal for every 25 startups to break even. (hope my math is right - somebody correct me if I goofed)
But I bought it hoping it would get me warmer a little earlier on my morning commute through city traffic, so I'm not in it for cost savings anyway.
mercynight
Jun 16, 2013 06:03 PM
subdewd
Jan 15, 2011 05:12 PM
ranger01
Sep 11, 2008 12:17 PM
philmcneal
Dec 18, 2005 07:17 AM
jdenenberg
Oct 28, 2005 03:42 PM
