Does waxing help mpg?
Old Dec 16, 2006 | 12:31 AM
twuelfing's Avatar
Default Re: Does waxing help mpg?
Originally Posted by Double-Trinity
For highway driving at least, aerodynamic drag accounts for over half of the vehicles fuel consumption, so a 10% reduction in that is very huge, that's as much of a change as Honda achieved in the Civic Hybrid by sealing the bottom of the car up with plastic panels, choosing flat rims, and lowering the ride height, all of which are very significant design changes by comparsion to a carwash -- those exposed exhaust pipes, bolts, and support bars that are underneath the car for example, must certainly be more of an impedance to airflow than a small amount of dirt over paint, and covering those up with smooth panels is less than a 10% difference in drag coefficient.
There will definitely be some difference, but I expect it to be very low.
Like I said before I have no sources to cite, however a coating of dirt over the entire surface area of the car is a very significant impedance to a nice laminar airflow.
I would love to see some actual stats on the effect of the drag relative to the surface condition of the car.
I think that without test data everything is speculation.
Old Dec 16, 2006 | 05:22 AM
Kephra's Avatar
Originally Posted by JoeFuture
My wife laughs when I suggest that keeping my HCH II shiny clean and waxed might actually help MPG. I figure in the city it probably makes 0 difference, but on highway trips, I expect it would help. Has anyone done experiments to see if this is true and to what extent?
Back a couple of decades ago, I tried several experiments with my airplane, and could see no difference in speed after waxing. If the drag coefficient had decreased, it would have resulted in greater speed at the same power settings. My plane was a Grumman Cheetah, which cruised about 150 mph.
Old Dec 16, 2006 | 05:52 AM
twuelfing's Avatar
It is telling that at 150mph a coating of wax didnt do anything noticeable. Could be different wind conditions on each of the trips measured.
I think we need a controlled wind tunnel test of this hypothesis.
Old Dec 17, 2006 | 07:00 PM
JoeFuture's Avatar
Joe Go Slow!
Double Trinity brought up something else I've been wondering about (to take this thread in a slightly different direction w.r.t. drag). the Insight has those covered rear wheel wells. I wonder if fashioning some similar covers for the HCH would have a noticable effect?
Old Dec 19, 2006 | 09:12 AM
ag4ever's Avatar
Dazed and Confused
I find this kinda humerous, mostly from that stand point of the same question has been asked in boating forums. There people wanted to know if waxing the bottom of a boat would increase the speed, and the consinsous was it does not help enough for you to notice. If that is the case for a surface running thru ater, I am 100% sure that there will be no change to a surface running though air.
The boundry layer on air is just to small to be significantly affected by wax or no wax. If there was any performance increase you would see extra people at the nascar races cleaning the entire car during pitstops.
Old Dec 24, 2006 | 07:38 AM
alloyz's Avatar
This comes into play at higher speeds, specifically on aircraft (commercial) where it makes a noticeable difference in fuel economy.
Over time (a long a$$ time) sure, a dirty car could prove to be less efficient than a clean one. Wax or no wax makes no difference, so long as the car is clean (no dust, dirst sticking to paint).
Old Dec 28, 2006 | 06:35 PM
zimbop's Avatar
It also helps if you keep your hair cut short to save weight. :-)
In all seriousness, I can't believe waxing would have ANY noticeable impact on your car's FE. Certainly no more impact than shaving off your beard. Given the enormous number of variables involved, I can't imagine even being able to detect something that miniscule.
It may however have an impact to you, so you can be certain you did absolutely everything you can think of to increase your FE. Some people just won't feel right until they've dotted every i, even the capitals.
bbmotor
Jul 28, 2010 11:34 AM
ncp10
Nov 22, 2009 04:38 PM
bmgoodman
Nov 29, 2006 06:21 PM
ozarkgolfer
Jun 27, 2006 08:34 AM
lars-ss
Jun 8, 2006 07:41 AM
