Do It Yourself oil change experience.
Old Apr 5, 2006 | 03:34 PM
privatejoker's Avatar
Default Re: Do It Yourself oil change experience.
Personally, I service my oil every 3000 mi with the honda 0w20. I would push it to 6000 mi if I could find synthetic. As far as that maintenance reminder, those are basically idiot lights. If you completely neglect your vehicle, they will remind you to change your oil. By the time your oil gets dark, you've got dirt and sludge on the inside of your engine. I prefer to change mine before that happens. 6k is also the proper interval for tire rotation.
Old Apr 5, 2006 | 04:28 PM
ElanC's Avatar
Honda provides a 5 year/60,000 powertrain warranty on the vehicle when it's maintained according to their schedule. They'd be idiots to recommend fewer oil changes than needed to keep the engine in good condition.
Old Apr 5, 2006 | 04:46 PM
hweldon's Avatar
Yes. Get yourself some ramps. I use those plastic ones. Costs about 17 bucks and work quite well.
As far as those "stinkin" clips, I replaced my with some I got at the local auto parts store. I think they were called "Rivet-Tite". They are plastic push rivets just like the OEM connectors but are much easier to take out and put back in. I've removed and reinstalled them about 3 times now and haven't broken a single one. Cost me about $3.50 for 10.
I have a 03 HCH, so I don't know if they are the same as the 06.
Howard
Old Apr 5, 2006 | 07:17 PM
RichC's Avatar
Ohio BIODZL Driver
Originally Posted by Tulip
Call me old fashioned! But I want to drain my hot oil and not suck it up a pipe leaving some residue in the sump somewhere! There has been discussion some where else on this site of a special tool for removing the sump guard clips and some clips that can replace the standard Honda ones for ease of use.
On the TDI it a different story. The extraction method removes more oil than the pan drain. (see video clip)
One of the quirky things about some diesel is that some housings retain oil. The extractor can be used to remove about 1/2 quart of old oil before putting in the new filter. Extractors have been used on boats for years ... although I suspect most of the 'gassers' with spin on filters probably drain just fine by the pan drain?
Old Apr 6, 2006 | 07:41 AM
grounded's Avatar
Isn’t this the Honda Civic Hybrid Forum?
I don’t care about some stinking diesel.
I drain my oil not suck it out.
Thanks anyway.
Take your diesel & extractor & go back were you came from
They might need this info back at your side of the table
Old Apr 6, 2006 | 07:43 AM
grounded's Avatar
Howard thanks for the information on the clips.
I think I was irritated because it was raining & i was doing it at night.
I reviewed my handbook last night & decided to change the oil & filter every 5000 miles using the honda oil for now. Thanks all U guys for helping me make up my mind on this issue.
Old Apr 6, 2006 | 09:01 AM
kmh3's Avatar
I have some nice metal ramps, but they are too tall for the civic
front bumper. I had some 2x4's laying around and that got the
car high enough I could crawl under it.
I considered the plastic ramps too, they look shorter than the
ones I have.
Old Apr 6, 2006 | 09:32 AM
grounded's Avatar
The one thing I found usefull with ramps.
I want to share this. It is for your protection
to keep them from sliding when you start up on them
place a piece of carpet under each ramp and extend it out on the approach
it really helps keep them from sliding on cement.
robwestcott
May 31, 2008 05:30 PM
rmorrow
Jul 10, 2007 03:37 PM
moosh
Nov 2, 2006 07:10 AM
stevenvillatoro
Oct 13, 2006 04:16 PM
Supercharged
Jan 13, 2006 08:49 AM
