Catalytic Converter Problems?
Old Feb 6, 2006 | 07:50 PM
psyshack's Avatar
Default Re: Catalytic Converter Problems?
Originally Posted by AshenGrey
Is there any way to get Honda to at least *partially* subsidise an out-of-warranty repair? Apparently the so-called extended warranty doesn't cover the catalytic converter, and a replacement costs over $1200. The first one failed at mid-40's, and now I'm at 92k and it's failed again. It's looking lemonesque.
That much for a CAT replacement. WOW!!! I would be doing it myself.
Old Feb 10, 2006 | 03:00 PM
AshenGrey's Avatar
Hybrid True Believer
Fortunately, I won't have to do it myself *or* pay. HondaCare agreed to replace the catalytic converter -- even though it was out of warranty by 10k.
Of course, that means I'm going to sell my HCH around 129,900 miles, har har.
Old Feb 10, 2006 | 04:19 PM
TheTurk's Avatar
Greetings!
So... Has anyone else had problems with the catalytic converter on the HCH-I? Mine had to be replaced at 50k miles, and now (at 92k) it's blown again. I'm glad that I purchased an extended warranty!
Is the catalytic converter a *known* component problem with 1st generation Honda hybrids, or am I just unlucky?
I met another civic hybrid owner, she had HCH1, she told me that she had the same problem as you, and extended waranty did not want to cover at first place, she had to deal with corp office. They eventually agreed to fix it under the extended waranty. It must be a recall or frequent issue then.
I hope this helps
Old Feb 10, 2006 | 04:40 PM
philmcneal's Avatar
04 prius 350,000km
so if you just got a HCH, get the update right away concerning the ECU and maybe the EGR valve if your having transmission problems.
Old Feb 10, 2006 | 06:57 PM
psyshack's Avatar
Very good!!!
Old Apr 20, 2007 | 08:58 AM
LlamaLarry's Avatar
The New Guy
Is the normal Honda warranty 80K for cats? I am at 103K so I am likely out of luck in any event, but was wondering if anyone has had luck getting Honda to spring for one at 100K+.
Old Apr 20, 2007 | 10:15 AM
cb450sc's Avatar
My cat went at 70 000 km. Engine check light went on so I brought it to the dealer. I have the extended warranty but the dealer said it was covered under the basic warranty.
Old Apr 20, 2007 | 01:14 PM
Has anyone looked into after-market CAT.. You can get them for most cars for around $100. I wonder why Honda is so expensive?
Old Apr 20, 2007 | 10:56 PM
MBNorCal's Avatar
in CA the HCH-II are smog exempt so i don't think we have to worry about that
mphillips
Jul 8, 2011 09:25 PM
hweldon
Jul 2, 2011 01:22 PM
z64dan
Dec 13, 2006 07:13 AM
spiff72
Sep 11, 2006 06:06 PM
wjanulin
Introductions
Mar 3, 2006 01:11 PM
