can you disable the auto up feature on drivers window?
Old Jan 2, 2008 | 08:54 PM
honda hybrid ny's Avatar
Default can you disable the auto up feature on drivers window?
I just installed rain guards on all windows, all the windows work fine except the drivers window. It pops out of the track during auto up. If I slightly nudge it little by little it will go up, but most of the time when it hits the top the auto feature kicks it back down.
thanks
kev
Old Jan 2, 2008 | 09:43 PM
Default Re: can you disable the auto up feature on drivers window?
It is a two way switch. Pull half way ,and you can stop the window at the point you let the switch return to off. Pull all the way and the window goes all the way up. Check the manual about disable.H
Old Jan 2, 2008 | 10:35 PM
gumby's Avatar
Energy Independence
True, Harold.
If it's popping off the track, this is a KNOWN defect that many have experienced (I've had it too). Search around on this site and you'll find tons written about it. Then, call your dealer and get it fixed under warranty.
Old Jan 3, 2008 | 08:26 AM
Kev: As for the window popping out of the channel, try lubbing the channel. How do you like the rain guards? I priced them last week at Honda. $198.00. I'm going to check the inter-net, may find them for less. Were they an easy install? Hal
Old Jan 3, 2008 | 09:57 AM
Black Ice's Avatar
You can remove the "auto up" feature by disconnecting the cable that is attached to that feature. You will still have the ability to roll the window up, as you wish, but not "auto up".
Old Jan 3, 2008 | 05:45 PM
Jess's Avatar
I was having the same issue w/ my window for a while. Then, one day, I noticed a piece of the weather stripping on the outside of the window was bent towards the inside. Apparently, the window was going up, hitting the stripping and going back down. Once, I corrected the stripping, the window has been working fine (knock on wood).
Jess
Old Jan 3, 2008 | 08:30 PM
Can anyone suggest a good lubricant? I purchased the WeatherTech 82416 Dark Tint 4-Piece Side Window Deflector thru Amazon. They were abut 90 bucks. It took about 5 minutes to install. The only problem I have with them is on the 2 front deflectors there is a small WeatherTech logo and phone number on them that I dont think you can peel off. I hate advertising.
I don't have the service manual,disconnecting the cable that is attached to that feature is a little vauge, can anyone elaborate.
thanks
kev
Old Jan 3, 2008 | 10:14 PM
Kev, take your car in to have the window repaired. This is a common problem with this car. Try a silcone spray. H
Aussie
Nov 27, 2009 10:10 AM
NWhybridguy
Oct 12, 2007 02:32 PM
FL07THC
Feb 5, 2007 10:27 PM
schmidtj
Aug 10, 2006 09:38 AM
zimbop
Nov 3, 2005 08:27 AM
