a/c vs. windows down - FE?
Old Apr 21, 2007 | 07:55 PM
hybriding's Avatar
Default a/c vs. windows down - FE?
How much more efficient is having the windows down as opposed to running the a/c? Because opening the windows increases drag from the wind coming in, decreasing FE. Another alternative is to have the vents open, but doesn't that increase drag as well? Anyone tried doing both and comparing FE? I tried searching the forums but found nothing specific in this regard..
Old Apr 22, 2007 | 02:08 PM
pagemap's Avatar
Default Re: a/c vs. windows down - FE?
Hello,
I have read that having the windows down with no a/c is about the same as having the a/c on and windows up. If you can, just run the vent if it's not too warm outside and leave your windows up.
Old Apr 24, 2007 | 02:34 PM
toast64's Avatar
This has been discussed in the forums before, but finding the thread might not be easy. From my recollection, the concensus (more or less) in the end was, less than 45 mph, leave the windows down - the drag created won't be that great. 45-55 mph, gray zone. Above 55 mph, better off using air than leaving windows down.
btw, MythBusters did a segment on this awhile back. They ran quite a few tests around a track. Their conclusion? They didn't come up with one. Their tests were inconclusive...
Old Apr 24, 2007 | 06:01 PM
Eskrimast1's Avatar
Wannabe Hypermiler
KLCarch conducted an experiment on this topic that might be of interest to you . . .
https://www.greenhybrid.com/discuss/...ht=windows+MPG
Old Apr 24, 2007 | 06:52 PM
iridium130m's Avatar
I do windows completely down at low speeds, windows partially down at mid speeds (40-60) and windows completely up at higher speeds with A/C on.
Windows partially up half way cuts down wind resistance quite a bit. My old accord picked up 2-5 mpg with the windows half way up compared to down.
wiredup
Aug 17, 2009 01:17 PM
druuu88
Mar 5, 2008 08:27 AM
tjq
Jul 5, 2007 07:21 PM
chasealicious11
May 28, 2007 08:45 PM
Kazdor
Apr 30, 2006 05:24 PM
