Auto Stop by shifting into N
Old Jun 13, 2008 | 06:07 AM
MasterAlex's Avatar
Default Re: Auto Stop by shifting into N
Originally Posted by sdgarber
the difference between your interior temp and your auto AC set point temperature, and even the coolant temp of the ICE.
If this is correct than any one of those factors would influence whether or not the auto stop engages. This almost seems like rocket science, doesn't it?!
What about if you press the econ button?
Old Jun 13, 2008 | 08:21 AM
HemiSync's Avatar
From the 2005 HCH Owners Manual, page 87
ECON Button
You can get better fuel economy with the Auto Idle Stop
function when you press the ECON button with the fan on.
When the ECON button is on:
  • The indicator comes on.
  • The Auto Idle Stop is enabled.
  • The system will not cool as quickly when the A/C is on.
  • The system turns off the ECON mode when you select or defrost or defrost/heat.
If the outside temperature is below freezing, the Auto
Idle Stop is disabled, even if the ECON button is on.
The heater will continue to warm the interior with the
vehicle stopped and the engine running.
When the ECON button is off, the Auto Idle Stop is disabled.
If the fan control dial is off, you cannot select the
ECON mode, but the Auto Idle Stop is enabled.
Old Jun 13, 2008 | 10:11 AM
msantos's Avatar
Eco Accelerometrist
Only the Gen 1 HCH's have the ECON button.
The Gen 2 HCH's have done away with it in part because the AC can be electrically powered while in Auto-stop.
Cheers;
MSantos
Old Jun 13, 2008 | 10:35 AM
MasterAlex's Avatar
sweet, when did the HCHII's come out?
Old Jun 13, 2008 | 11:14 AM
msantos's Avatar
Eco Accelerometrist
Fall of 2005 as a 2006 model.
MSantos
kklein
13
Jan 28, 2010 01:10 AM
Myrddin157
May 24, 2007 06:08 PM
grayhawk
Sep 11, 2005 05:55 PM
merlin180
Jun 27, 2005 05:56 PM
MoJoWryter
Jun 23, 2005 12:52 PM
