Alarm Honk
Old May 24, 2006 | 07:58 AM
HCH-Jun's Avatar
Default Alarm Honk
I hate how when you press the lock button twice in succession to activate the alarm it honks the horn, especially since the horn sounds so whimpy (in relation to the whimpy horn thread). Every other car I've owned would beep instead of honking the horn. Is there any way to change this?
Old May 24, 2006 | 08:14 AM
Katz6768's Avatar
Happy Hybrid Owner
Default Re: Alarm Honk
I understand that you don't need to press the LOCK button a second time.
Unless you want to verify that the doors are locked and the security system set:
...From Owner's Manual
LOCK
Press this button once to lock all doors. Some exterior lights will flash. When you push LOCK twice within 5 seconds, you will hear a beep to verify that the doors are locked. You cannot lock it if any door is not fully closed or the key is in the ignition switch.
If you push the LOCK button twice within 5 seconds, you will hear a beep to verify that the security system has set.
Old May 24, 2006 | 08:18 AM
HCH-Jun's Avatar
I guess the reason why I press the lock button a second time is because I can hear the horn to verify that it's been locked. During the day sometimes I cannot see if the lights blink or not. Since I've gotten the car, people who have rode with me have not closed the doors all the way shut and when I attempt to press the lock button the second time the horn doesn't go off. This is what let me know that the car alarm wasn't activated and a door is open.
Old May 24, 2006 | 11:01 AM
geeckk's Avatar
...Every other car I've owned would beep instead of honking the horn. Is there any way to change this?
I think it is something Honda does (using the horn instead of a beep). My '03 Civic did this as did a friend's CRV.
I use it for the same reason - to "verify" it is locked. Though the horn is a little wimpy, I'm used to the "honk" instead of a "beep".
Old May 24, 2006 | 01:16 PM
HCH-Jun's Avatar
Must be a honda thing only because the TL I traded in and my fiance's TSX both beep when pressed the lock a second time. I guess it's considered a luxury to have a car without a wimpy sounding stock horn. I'll have to live with it.
Old May 24, 2006 | 03:46 PM
dgkenney's Avatar
My wife's Murano (Nissan) does the same thing - (horn honk for verification)
Dan
Old May 24, 2006 | 05:16 PM
Anahymbrid's Avatar
Our Isuzu Trooper did the same thing, but it had a separate horn for the alarm. I just stuffed a rag in there to tone it down a bit. Wouldn't want to do that with the HCH, though!
Seems the real difference between the Civic horn and the more pleasant sounding horns (on other vehicles) is the fact that the others are dual note. Wouldn't it be possible to add a second horn in the circuit on our Civics?
Of course, this won't change the issue of the alarm just beeping vs. horn honking, but at least the horn would sound better!
dpmitche
Jan 5, 2013 04:23 PM
konrod
Feb 4, 2008 07:57 PM
Hightower
Sep 27, 2005 08:00 PM
parrot_lady
Aug 11, 2005 09:35 PM
MissKitty
Jun 23, 2005 06:13 AM
