06 hybrid nearing 100,000
Old Feb 19, 2009 | 06:51 AM
Utah's Avatar
Default 06 hybrid nearing 100,000
Hey guys, I haven't been on this board in a LONG time, so HI... Anyways, I have an 06 that I bought new and have always kept up with all maintenance (oil changes, air filters and tire rotations). I recently looked through the books that came with the car, but there is no schedule of major maintenance. I'm trying to find out what is going to be needed just so I can start to save and be prepared for it. Everywhere I've looked, all I can find is, "Just follow the maintenance reminders that the car will notify you of". Does anyone have any more insight on this?
Secondly, how dependable is this engine? I obviously bought this car when it first came out and due to it being a new model, there really were no reviews in regards to longevity. What have you guys been hearing / reading in regards to how many miles people are getting out of their car? Just curious since I still have 2 more years left till this thing is paid off...
Thanks in advance...
Old Feb 19, 2009 | 08:12 AM
Default Re: 06 hybrid nearing 100,000
Hi John;
I believe there are a couple items listed in the manual. After 3 yrs. change brake fluide and adjust valve around 100,000 miles. There may be others, but can not think off them at the moment. I think the engine is good for a couple more 100,000 trips! Are you pleased with your car and has it been trouble free? I have only 35,000 kilomiters on my 2006 and it has been trouble free.
Cheers, Hal
Old Feb 19, 2009 | 08:51 AM
Utah's Avatar
Thanks for the reply Hal. I've gotta say, I've been very pleased with the car. Im currently right at 92,000 miles and I have had no major maintenance needed yet (knock on wood). There are a few quirky things about the car that I have learned to live with. One for instance is on occasion, when I attempt to raise the volume on the radio through the steering wheel button, it will instead change the channel. But I've discovered that as long as I lower the volume once, then attempt to raise it, I have no problems. Little things like that I can easily live with...
Old Feb 19, 2009 | 09:06 AM
John;
What type of tire are you running? Did you stick with the LRR type? Some members have changed the upper control arm due to negitive camber problem. I.E. tire wear and road noise. Has this been a problem with your 2006? Hal
Old Feb 19, 2009 | 09:19 AM
larryr's Avatar
2nd Hybrid Owner
I believe all Honda 4 cyl. engines require the timing belt and water pump to be replaced at 100,000.
Old Feb 19, 2009 | 09:24 AM
I thought it had a timing chain? H
Old Feb 19, 2009 | 10:31 AM
Utah's Avatar
Originally Posted by Harold
John;
Hmmmm, Negative Cambar does make sense now. I wasn't aware of that problem and apparently my dealership wasn't / isn't either. About 8 months ago I went in for an oil change and they discovered my rear tires were like this: Name:  tirewear.jpg
I'm not exactly a "car guy" so to speak, so I was a little baffled about this. I asked the mechanic what would cause this when the front tires were not noticing this sort of ware. Or, how this could happen in 1 months time. I say 1 month because either it wasn't like that during my last oil change (due to the amount of miles I put on my car back then, I was having my oil changed close to once a month), or it was, and my dealership completely missed it and never noticed it. Eitherway, they had no answers for me as to why this would or could happen. Now I pay additional to have my tires rotated at EVERY oil change.... But to be honest, even when my tires were wearing like that, I never experienced any additional road noise...
Old Feb 19, 2009 | 10:32 AM
Utah's Avatar
This was the type of info I was looking for. Major maintenance... Are we sure of this though?
Old Feb 19, 2009 | 12:11 PM
Mendel Leisk's Avatar
The 2006 Civic, at least the hybrid, does not have a timing belt. It has a timing chain. I can look it up tonight (in Service Manual), but I don't believe there is a change interval. And the water pump change is just for preventative maintenance, if you have it opened up to get at the belt it's just a good time to change the pump as well.
I would just follow the maintenance minder and the the few time specific items noted in the owners manual, Harolds mention of brake fluid change every three years, for instance.
I jumped the gun and did my own valve clearance check, well ahead of the likely Maint. Minder interval, just my preference.
Old Feb 19, 2009 | 04:23 PM
John,. Take it in along with the picture and maybe Honda will cover it Hal
