What Replacement Struts Have You Used
Old Feb 14, 2009 | 08:44 AM
lebloom's Avatar
Default What Replacement Struts Have You Used
My 05 HAH has over 100k on it and I feel its time to replace the struts. MY mechanic gave me a $700 figure for a really nice set but that sounds too high. Has anyone out there replaced theirs yet? Bought this car used and figured it would need new struts sometime in the next 2 years but maybe its time sooner if can find one that won't eat my wallet.
Old Feb 14, 2009 | 09:18 AM
Mendel Leisk's Avatar
Default Re: What Replacement Struts Have You Used
We had a 91 Accord for about 15 years, albeit with a lot lower per-year mileage than yours: it never even occurred to me to replace struts. Is there something amiss with yours?
Old Feb 14, 2009 | 09:27 AM
lebloom's Avatar
The ride, its too tight. Here in IL the highways are rough. I am looking for something to take the roughness out it. I had an 04 Buick Regal which also had a sporty suppension but it had a much better ride. And both the Accord and the Regal were the same length but the Accord rides alot rougher. Not quite sure if the Accord was fitted with a sporty suppension or what. I replaced the tires just last year and that made the ride some better but not enough.
Old Feb 15, 2009 | 01:46 PM
houseofcharm's Avatar
May not be the struts but the spring rate. US cars and some Jap often overspring and underdamp their shocks and it makes a stiff pogostick ride(mustang GT, Subaru Forester XT among others).
Old Feb 15, 2009 | 01:59 PM
bar10dah's Avatar
Hmm, generally you can tell you need new struts when the ride is too soft. Actually, when it oscillates more than once or twice after hitting a bump. If the suspension is tight, where it very quickly stops the oscillations, then I'd rule out the struts.
Since I've never ridden in your HAH, I can't comment on the way your suspension behaves. However, mine feels better than a regular sedan suspension. A bit more sporty. Although, not as sporty and tight as the suspension in the TL. When I bought my '05 HAH, I test drove the '05 TL and could definitely feel the TL's suspension was tighter. As it should, being more of a sporty car than the HAH.
If I recall correctly, the optional sport struts available for the V6 Accord is about $700 from www.handaaccessories.com. Unfortunately, it's not compatible with the HAH or I'd be looking at those when it comes time to replace them. I don't know anything about aftermarket struts for the HAH, or about how much they'd cost. Shop around? One thing that I'd caution is that after paying $700, if the stock HAH suspension is too tight for you, you more than likely won't like the feeling of a more sporty suspension, as it'll be even tighter than stock. Maybe you should look at struts that aren't and upgrade, but rather a downgrade? From the sounds of it, you like the softer boat-type car suspension? I think I know what you're describing because I have an old '59 Ford that has such a suspension. It felt like it floated over bumps. However, the car rocked and swayed a bit too much for my liking. Especially during 'spirited' driving. Another thing I can think of that'll give you the feel you're looking for is buying a smaller wheel and using higher sidewall tires. Keep the same tire diameter, but by making the wheels smaller and the rubber larger, the sidewalls should absorb a bit more of the impacts for you. However, buying new wheels and even tires (since you just bought new tires) is probably out of the question.
Old Feb 16, 2009 | 02:58 PM
lebloom's Avatar
So, what can be done about this if this is the problem? Probably can't do anything to change this can I?
Old Feb 16, 2009 | 03:00 PM
lebloom's Avatar
What am I stuck with this kind of ride?
Old Feb 16, 2009 | 03:17 PM
You can modify the springs and/or the struts but you'd need to find sources-something I have no clue about. Eibach is usually much harder than stock. You can also find a good spring winder to custom make some springs. i like progressive rates where the 1st few inches are Caddy soft and then stiffen up on the bigger bumps. Peugeot had this down perfectly in the 60-70s, caddy ride mainly and then set like a sports car on turns and bigger bumps.
Old Feb 17, 2009 | 08:57 AM
livvie's Avatar
I can't imagine a strut going in that short of a time frame. You are probably use to a softer ride in the buick.
Old Feb 17, 2009 | 09:14 AM
And if struts went bad that quickly, it'd probably only be one of them that was defective, not the pair from wear.
