Replacing battery
Old Nov 17, 2014 | 06:55 AM
sedali's Avatar
Default Re: Replacing battery
By the way, I am going to get the MAX-IMA from Bumblebee.
Old Nov 17, 2014 | 06:56 AM
Yes. Quarterly grid charging will minimize imbalance. I would go with the battery supplier's recommendation.
Grid charger here:
http://hybridautomotive.com/gc/shop.html
Old Nov 17, 2014 | 07:00 AM
sedali's Avatar
And after it is replaced the lights will be reset and go off on their own or it needs to be reset by some equipment? In case I find a way to do it myself or by a friend.
Old Nov 17, 2014 | 07:07 AM
As a safety measure, one should disconnect the 12V battery when working on the IMA system. The 12V disconnect will reset the codes and force an initial recalibration when the IMA battery is installed. If the battery was the cause if the IMA/check engine light, then it should be reset and stay off.
Old Nov 17, 2014 | 07:08 AM
Good choice. Go with their recommendation on a grid charger.
Steve
Old Nov 17, 2014 | 07:09 AM
sedali's Avatar
Thanks, very helpful.
Old Nov 17, 2014 | 07:56 AM
Many thanks, Keith.
This morning when i was driving to work, I noticed that although all the bars and indicators are working normally (except for the IMA and engine light being on), the autostop does not work at all. So when I was stopped and there was no load on the system (AC, lights, etc were off), the engine didn't go on autostop. I guess that should be a sign in favor of IMA battery problem?
Missed this earlier. A couple dozen criteria have to be met before auto stop will function. Pretty sure an IMA indicator light disables auto-stop to minimize load on the battery.
Steve
Old Nov 17, 2014 | 08:02 AM
sedali's Avatar
Good to know. So your last post tempted me to learn how to take out the back seats (my main reason for hesitating so far to do the replacement myself), get one of those grid chargers to do it myself and see what happens
Thanks again. I may have more questions when I start doing it!
Old Nov 17, 2014 | 08:07 AM
sedali's Avatar
Keith is there a reference manual or something close to that regarding the workings of the IMA system that I can read before getting too deep into this?
Old Nov 17, 2014 | 08:20 AM
Not to my knowledge. All my experience is with the Civic Hybrid. I recommend you engage in Google-Fu.
Accord hybrid battery installation video:
