navi diagnostics
Old Nov 28, 2005 | 05:10 PM
tbushatz's Avatar
Question navi diagnostics
does any one know what the F-CAN is under the navi system diagnostics?
when i pull F-CAN up in my navi it currently says ERROR ACTIVE?
does anyone know what this means or know what theirs says?
the B-CAN checks out all OK and is kinda self explanitory.
Old Nov 28, 2005 | 05:53 PM
gauthig's Avatar
Default Re: navi diagnostics
B-CAN -> the Body Control LAN controls functions including power windows, relay modules, etc.
F-CAN -> the System Control LAN —with the F signifying fast, as it communicates at 500 Kbps vs. 33.33 Kbps for the B-CAN, controls the engine and transmission ECU
The error active is normal as it means a previous error has been recorded and could be as simple as the last time you needed an oil change, or lost GPS single. You need a auto scanner to pull the codes.
Old Nov 29, 2005 | 05:33 PM
tbushatz's Avatar
should i get the codes cleared or just leave it alone?
how would i know if there is a new problem if it always says error active?
Old Nov 29, 2005 | 06:19 PM
gauthig's Avatar
As I understand it, it keeps a log of all past errors (even though it states active error) and should remain for in-depth debuging by Honda. It does not hurt anything to keep all the old events.
The Navi diag program is not to be used for seeing or clearing ECU events, it is just a status of the connection between the navi unit and many other components.
Also note, that there is a clear memory function in the diag menus, this will only clear your personal settings and addresses (HOME) from the system. Do not use.
test54
Jul 1, 2008 08:02 AM
WildViper
Mar 25, 2008 05:28 AM
badda1k
May 20, 2007 05:33 PM
shomrighausen
Jun 16, 2005 04:17 PM
TXRPh
13
Apr 22, 2005 11:21 AM
