N coast vs 'hold the line on 3cylinders'
Old Sep 30, 2005 | 12:32 PM
Lewis's Avatar
Default Re: You should never drive auto tranny in "N"
Originally Posted by gonavy
ok, but who's revving the engine in N and why would one do that? If I were in a '69 Mach 1 at a light and something fast looking pulled up next to me I might consider it, bt otherwise??
As I understand Mitaka's post, he raises two possible problems from N coasting;
one is unintentional engine revs in N coasting (say, a long coast, and forgetting it was in N??? and starting to accelerate while still in N???) and possible damage;
the second is that transmission gears do turn when coasting in N, and that the engine at idle may not pump enough oil to properly lube the gears, especially at higher speeds?
My read, and I don't have any hard tech knowledge to confirm or to deny.
Lewis
Old Sep 30, 2005 | 05:42 PM
Mitaka's Avatar
Default Re: N coast vs 'hold the line on 3cylinders'
My point is that if you drive in neutral and you don't have proper flow of ATF you will fry your tranny.
Old Oct 8, 2005 | 01:37 PM
xcel's Avatar
Hi GoNavy:
___Sorry I did not get back to your earlier …
Reset FCD w/ 2.1 miles total. 52 mph - 28.4 mpg initial when FAS performed at overpass sign just before a high speed off-ramp and coast into a gas station. Final 50.0 mpg.
Reset FCD w/ 2.1 miles total. 54 mph - 29.9 mpg initial when a Neutral coast was performed at overpass sign just before a high speed off-ramp and coast into a gas station. Final 41.2 mpg.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old Oct 8, 2005 | 05:03 PM
gonavy's Avatar
Thanks. That pretty definitively closes the book, I think.
Old Mar 20, 2006 | 12:08 AM
philmcneal's Avatar
04 prius 350,000km
Lewis
replies like that, make me wonder if I should coast in N with an automatic or not....but its there for a reason right? I mean the car developers wouldn't put it there unless they knew it was useful for something... not something that can kill the car!
So abuse it!
Curated Content Editor
May 22, 2013 07:00 AM
rharper
Apr 3, 2007 11:12 AM
Panny
Feb 8, 2007 07:16 AM
bar10dah
Aug 15, 2006 11:16 PM
Jason
Website Questions & Input
Mar 6, 2005 08:33 PM
