View Poll Results: get the fog lamps? (poll closes in 30 days after 11-28-05)
yes
10
45.45%
no
10
45.45%
don't care
9.09%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
Fog Lamps
Old Nov 28, 2005 | 10:12 PM
bar10dah's Avatar
Default Fog Lamps
I'm considering getting them. I believe they're around $230 online. It's hard to justify getting them because they're just so expensive!
Who here has them on their HAH? Do you notice any improvement over just using the headlights? See any farther? Better? What are your opinions on them?
Old Nov 29, 2005 | 03:33 AM
gonavy's Avatar
Default Re: Fog Lamps
our low beams are aimed pretty low already; seems like a lot of $$ for little payoff other than a unique front end. I don't think I've seen any 7th gen Accords with them.
Not much need for them around here, either, though.
Old Nov 29, 2005 | 04:24 PM
daddywags's Avatar
Are they amber? I had amber fog lights on my Acura Legend and they made a nice improvement in dense fog.
Rich
Old Nov 29, 2005 | 05:28 PM
bar10dah's Avatar
I wouldn't get them with ambers. (they're clear, stock) I'm not concerned with fog. So, I shouldn't call them fog lamps. What I need are driving lamps.
Old Nov 29, 2005 | 08:58 PM
Delta Flyer's Avatar
Banned
I suspect foglights sold more for "coolness" rather than utility. Good point that most of us are already driving low to the ground. But maybe it really is a safety feature.
Old Nov 30, 2005 | 06:43 AM
Archslater's Avatar
Enthusiastically Active
If aimed properly, fog lamps only really help in low visability situations like fog, heavy snow fall, etc.... as their beam tends to be low and wide. I suspect you get little of either in Arizona, so they would just be for the cool factor. I used to live in a very rural area, and there was often fog at night, in which they helped dramatically. Since I have lived in the city, I have never had them, nor have I really needed them.
If you are just buying them for appearance, you might consider getting a cheaper generic version at a dept. store.
Old Nov 30, 2005 | 06:44 AM
lars-ss's Avatar
Not much Fog in El Mirage.......I'd say get them if you want them for the LOOKS, but as mentioned, they won't really help you much in "no-Fog AZ."
Old Nov 30, 2005 | 10:19 AM
laurie's Avatar
my other car is a FJORD
can i rant a little? around here it seems like every single large or fancy vehicle has them, and most pickup trucks. fine. but they run with them on all the time! i get blinked at when i forgot to dim my lights, yet these days a truck can be coming at you with maybe up to ten lights on in the front, and that's not considered the same as brights? they have their headlights, the high intensity fog lights, running lights next to the head lights, lights on the cab, and sometimes an extra set on the front just to look cool. meanwhile, those of us that they are either passing or coming toward are covering our eyes. what gives?
and don't get me started on the blue ones or the really high intensity yellow ones that burn out your retinas as they come up behind you.
Old Nov 30, 2005 | 11:23 AM
ralph_dog's Avatar
World's First Hybrid
Hi Laurie,
I believe that there is a Fed DOT requirement for headlights and fog's and how many or how intense they can be. I feel your pain as this happens to me all the time. The HID headlights are only legal on cars that come factory equipped with them (they have the correct reflectors/lens assemblies). The aftermarket Kit HID's are not legal unless the reflector/lens assembly has a Fed ID number with HID imprinted on it. All other HID's are not street legal, (only meant for off-road use).
The big pick ups and SUV's with all the added off-road lights should not be using them on reg highways. You may be able to verify this on the DOT or NHTSA website.
http://www.consumerreports.org/cro/c...3/overview.htm
http://www.autoaccessorystore.com/ho...=detail&id=479
And if you're having problems sleeping, try reading this NHTSA tome...
http://www-nrd.nhtsa.dot.gov/pdf/nrd...20spectrum.pdf
Old Nov 30, 2005 | 11:48 AM
Banned
....yet these days a truck can be coming at you with maybe up to ten lights on in the front, and that's not considered the same as brights?....
That's when I wish for extreme flashbulbs mounted in the rear of my car. Not only would it blind them, it would fry what little brain was left.
Seriously, the laws should address monster trucks/land barges for the safety hazards they are, not to mention the increased highway wear....
