Wiper Blade Sticker Shock
Old Mar 10, 2010 | 02:51 PM
  #31
Default Re: Wiper Blade Sticker Shock
Just had my rubbers replaced on my 2006 and it only cost $12 installed I was very pleased. Hal
Old Mar 10, 2010 | 08:00 PM
  #32
Mendel Leisk's Avatar
Just checked my receipts: I payed $5.95 plus tax (Canadian) for just the parts. Good deal from your dealership Harold, because replacing those is not easy.
Old Mar 11, 2010 | 07:53 PM
  #33
Bobs Metallic Pearl's Avatar
I just paid $16.95 us for the pair, installed by the dealer.
Old Mar 11, 2010 | 08:29 PM
  #34
jeff618:
I just had a look at a pdf 2009 Owners Manual, and yes, Honda has gone back to a more conventional wiper blade. Our '06 is a royal bear, getting the blades out, and that's after you manage to get the assembly off the arm. That is unless you want to do the whole operation leaning over the car. The Owners Manual description and pictures regarding how to get the assembly off the arm is out-to-lunch: pictures are reversed. I finally figured it out, but the book was no help.
Old Mar 12, 2010 | 07:52 AM
  #35
I've been listening to all of the whining about how hard it is to change the HCHII wiper inserts and I just don't get it.
I did an insert change at my 60K maintenance and it was a breeze. Taking the wiper carrier off of the car was no more difficult than any other car, and changing the insert was no big deal either.
I just squirt a little soapy water on the blade inserts and use some painters tape to hold the metal stiffeners in place until the insert is in the arm, it just slid right in.
The only thing I had an issue with is that the left and right blades are not the same length, and I had the inserts switched the first time I did it.
Even with my screwup it only took about 5 minutes to do both blades. I just don't understand what all the consternation is all about.
Old Mar 12, 2010 | 08:12 AM
  #36
I watched the guy that changed mine . He did not remove the blade from the arm. All he did was lift it and reach under the aft end and pull the locking end down about 1/4" and then pull the rubber out. Put the metal strips in the new rubber and slide it back into its spot. He did both wiper blades in 5 min. Just that easy!!! Hal
kpdandjad
May 14, 2011 06:41 AM
UWAdventurer
Dec 5, 2010 12:10 PM
icebluemariner
May 29, 2009 10:35 AM
zimbop
Mar 26, 2009 02:55 PM
Doug
Mar 5, 2009 01:03 PM
