Recommended Tire Pressures ???
Old Mar 1, 2010 | 03:23 PM
Smurf's Avatar
Default Re: Recommended Tire Pressures ???
I live in Phoenix, AZ and I keep my tire pressure at about 40 psi without any issues....
It can't get much hotter than it is here...
Old Mar 6, 2010 | 06:17 AM
Mendel Leisk's Avatar
I think different tires give different ride characteristics at higher pressures. We've got Nokian WRG2's on in the winter months, and setting them to 45~ psi gives a fairly rough ride: they just don't give as much as our regular tires. The OEM Bridgestone Insignia's have a bit more flex at similar pressures. With the WRG2's I backed them down to 40, didn't seem that detrimental to mileage.
Old Mar 9, 2010 | 02:38 PM
iridium130m's Avatar
i run mine around 38-42psi depending on road conditions...too high of pressure works the suspension harder on rough roads. The slight loss in mpg is much cheaper than replacing struts or a bent rim, especially in the midwest here where potholes are common and roads are in terrible condition after our latest winter.
birchman2
Jul 13, 2006 05:37 PM
CamelFilters
Mar 10, 2006 02:47 PM
ender21
Toyota Highlander Hybrid
Sep 25, 2005 10:51 AM
AZCivic
Off Topic
Jul 30, 2005 08:38 AM
xcel
Feb 23, 2005 02:48 PM
