Oil Change Price Increase
Old May 30, 2008 | 08:10 AM
kristian's Avatar
Default Re: Oil Change Price Increase
Holy Cow! Is that because of the "special" 0-20w or because it's a hybrid? Or is that the standard cost in your neck of the woods?
Changing my own oil again is a bit of a PITA, but I decided it was worth it from a "control" perspective. Now I see it's also worth it from a $$ perspective!
Old May 30, 2008 | 08:43 AM
peking's Avatar
I was bored, so, I called the local Honda dealership. Looks like they want $47.69 at Brookdale Honda in MN.
Old Jun 1, 2008 | 04:56 PM
GardenWeasel's Avatar
Originally Posted by Mr. Kite
GREAT link! Thanks!! One question - will ramps to lift car for easier access work in lieu of jacks and jack stands? Or is the HCH too low to go up ramps? TIA
Old Jun 1, 2008 | 06:06 PM
Mr. Kite's Avatar
I have these ramps mentioned here:
https://www.greenhybrid.com/discuss/...er-auto-14352/
I got my Civic up on them, but I slipped a little bit doing it. (I think I just didn't give it enough gas to get all the way up and gassed it again after sliding down.) That can do some damage to the ramps--it melts them a bit. Anyway, after I got it up, I decided I was too lazy to do it. I took it to my local Honda dealership (Go Honda in Westminster, CO). I supplied the 0W-20 Mobil 1 Synthetic and a PureONE oil filter. I just pulled the receipt to check and I was charged $16.75. (I had to go in anyway for some recall work.) That was in January of this year.
Old Jun 1, 2008 | 06:12 PM
Much thanks! Mine that I've been using for many years with my other Hondas appear identical to those in the link. I've due my first oil change in the HCH soon. You 'done good' at your dealer!
Old Jun 3, 2008 | 06:46 PM
HemiSync's Avatar
My local Honda dealer in PA wants $48 for the change with oil & filter.
I use the good old fashion steel car ramps for my oil changes. Even when I have had a vehicle that I wasn't sure about driving up on them I just use my floor jack to raise it and slip them under the wheels. I have stands also but I never really like using them if I don't have to.
Haven't done an oil change in the HCH yet, only got it two months ago & the dealer had just changed it. So will be interesting to change the HCH. I can't imagine the undercover being that bad to remove. Luckily some of the stores in my area finally started carrying the Mobil 1 0W-20 Advanced Fuel Economy. I know some people have had trouble finding it and I had great luck using their product locater on their website.
Last edited by HemiSync; Jun 3, 2008 at 07:31 PM. Reason: Added link for Mobil product locater
Old Jun 11, 2008 | 09:41 AM
bishop's Avatar
Had it done yesterday for $75 at a Tires Plus around the corner that I have been going to for years. That might be the last time I go.
They told me they ordered 4 quarts but I see in the D-I-Y link that only 3 are needed. Who is correct?
Old Jun 11, 2008 | 10:28 AM
HemiSync's Avatar
3.4 US qt including filter, most people use three because it brings it up to halfway between the two marks and insures that it is not overfilled. Your Tires Plus owes you at least half a quart and about $30 for overcharging you.
Old Jun 11, 2008 | 05:01 PM
Jess's Avatar
My dealer typically uses about 3.5 quarts of oil that I bring in, but this last time they put 4qts. I was a little upset but decided it would be okay. It filled right to the full mark nd haven't noticed a difference in performance. Next time, though, I will give them only 3.5 quarts to put in. My dealer charged around $23.
Old Jun 11, 2008 | 07:36 PM
holicow's Avatar
Ramps not necessary. Just undo the 4 fasteners at the front of the plastic cover and the front will drop down giving easy access to the filter.
Use your oil extractor to remove the oil from above.
I finished in about 15 minutes...and this was the first change. Next time should be about 5.
