Non Hybrid civic alloy wheels on Hybrid
Old Jul 10, 2008 | 08:13 PM
holicow's Avatar
Default Re: Non Hybrid civic alloy wheels on Hybrid
I don't recommend any rim greater than 16" because larger rims will require a lower profile tire and that may compromise the rolling diameter of the tire, not to mention ride comfort.
What do you mean by that term? Deflection of sidewall?
Old Jul 11, 2008 | 06:53 AM
What I mean is how big the outside diameter of the tire is. That affects the speedometer accuracy, and the bigger the rim, typically the shorter the sidewall of the tire which affects the ride quality.
Old Jul 11, 2008 | 07:46 AM
noflash's Avatar
Also the larger the rim -- even if the weight is the same -- negatively affect FE, because the weight is further from the center.
nf
P.S. Don't fear the rings. I've been using them for years and have never had one break.
Old Jul 12, 2008 | 03:02 PM
pcope's Avatar
Rookie Enthusiast
may I add a rookie question? Is there an advantage to putting 16" wheels on the HCH II, besides styling issues?
Old Jul 12, 2008 | 03:42 PM
Brawn's Avatar
Here is a link to tirerack.com they have 235 different styles of Alloy wheels to choose from for the Civic. If this link works you can choose your car color and see what the wheels look like on your car. discounttire.com also has the same feature.
If this link Works there should be an Atomic Blue Civic Hybrid.
http://www.tirerack.com/upgrade_gara...ModClar=Hybrid
Just click on the wheel you like and you can see it on the car. They also have steel wheels. You can do this for any vehicle.
Old Jul 13, 2008 | 01:54 PM
holicow's Avatar
The larger the wheel diameter, the lower the profile of the tire, if you size it correctly. In the end, the diameter should be the same. That's how you pick tire size to match your wheel if plus-size.
Old Jul 13, 2008 | 03:12 PM
pcope's Avatar
Rookie Enthusiast
so why get larger diameter wheels for the HCH II?
Old Jul 13, 2008 | 03:47 PM
I would recommend getting 16" wheels and tires as that is what the car was designed for. 17 or larger will compromise the car.
Old Jul 13, 2008 | 06:44 PM
holicow's Avatar
Gotta go for the bling, baby!
Just kidding, I like my dinner plates just fine.
Old Jul 14, 2008 | 11:51 AM
pcope's Avatar
Rookie Enthusiast
so here's where I'm probably being dim. My '08 HCH II came with 15" wheels; was the '07 sold with 16", or are there model diffs in the '08?
(knowledge is power!)
