Need Tire Replacement Recommendation
Old May 5, 2009 | 11:49 PM
  #61
thilmony's Avatar
Default Re: Need Tire Replacement Recommendation
3 days in, these tires seem fine for MPG. However, I feel like I am all over the road now. I literally checked my wheels to make sure the lug nuts were tightened as I find myself cross the center line or running toward the shoulder. Just gotta get used to it I guess.
Old May 6, 2009 | 07:44 AM
  #62
stevenvillatoro's Avatar
Arrow Re: Need Tire Replacement Recommendation
An unexpected bit of feedback. What tire pressures are you using?
Old May 6, 2009 | 07:46 AM
  #63
thilmony's Avatar
45 psi. i have to confess i have not had an alignment yet since upper control arms were replaced. but i can't imagine that's it.
Old May 6, 2009 | 07:54 AM
  #64
I run 42/40 PSI, and have never run higher pressures in my HCH tires. You likely were running 45 PSI on your former tires, as well. My Insight I was very 'squirrely' at higher pressures (45+) and would give the symptoms you described.
Alignments are cheap insurance – surprised that wasn't done when control arms were replaced.
Old May 6, 2009 | 07:56 AM
  #65
thilmony's Avatar
they offered it but said if i was replacing my tires (which i was in a week) that it would be a waste. i probably should have let them do it anyway.
Old May 22, 2009 | 10:04 AM
  #66
Lansing's Avatar
Default Rolling Resistence Question
I am going to need new tires soon. I want something quiet and stable, and having low rolling resistence would be nice, too.
How do I tell if the tire's going to give me good mileage???
Thanks,
Lansing
Old May 22, 2009 | 07:43 PM
  #67
There are some good up-to-date recommendations on this site, cleanmpg.com, and other hybrid sites.
Old May 28, 2009 | 11:09 AM
  #68
Lansing's Avatar
Ok, I have been doing a little research. My HCHII tires (Bridgestones) are aging and starting to make a lot of noise (I actually hope it's the tires--the hybrids aren't quiet to begin with).
Tirerack says that LRR tires were typically poor performers but things are getting better. Here is what I see as choices:
- Bridgestone Ecopia EP20 $85 each
- Bridgestone Insignia SE200-02 $71 each (stock tire)
- Goodyear Assurance Fuel Max $79 each
- Kumho Solus KR21 $59 each
- Yokohama AVID TOURING-S $61 (maybe a little heavier?)
I would like a tire that is quiet, comfortable and safe. Good gas mileage would be nice, too. It's hard to justify buying a hybrid only to do things that compromise MPG.
What's your choice and why??
Thanks,
Lansing
Old May 29, 2009 | 03:01 PM
  #69
Mendel Leisk's Avatar
I've been wondering if there's a mileage hit going from SE200_02 (the stock tire, somewhat limitted availability), to the SE200, which I believe is more readily available. Some of the spec's. are different: the tread depth is more on the SE200, the weight is more, and there's a profile dimension that's different. None of the variations are big, and the pictures at TireRack look quite similar, but not identical.
Old May 29, 2009 | 06:27 PM
  #70
I think the Ecopia EP200 and Goodyear Assurance Fuel Max sound like the most promising LRR tires now available. The latter has been reviewed by a couple of people on here... still waiting for our Guinea Pig to test thte Ecopia EP200. I only have 1000 miles on my car, so there's little incentive unless y'all want to chip in.
