Need help diagnosing IMA/battery troubles
Old Apr 3, 2018 | 02:17 PM
  #31
bakageta's Avatar
Default Re: Need help diagnosing IMA/battery troubles
Originally Posted by TragicallyHip
Correct me if I"m wrong, but this here is a bad fuse and may be the source of my troubles.
So I just thought I'd post to say I had the same issue, and this post was a lifesaver. It saved me a ton of time tracking down my problem. I've only had my HCH2 for about a month, it was running absolutely perfect and averaging 43-45mpg in the 1500 miles I've had it, when it didn't restart after an auto-stop at a light. Restarted from the traditional starter, same batt/IMA/CEL lights when restarted with only the P0AE1 code. 12v battery replaced 3-6 months ago, has a manufacture date of 6/17 so at worst 10 months. All wiring looked great, and my IMA voltages looked great to me, so I just replaced the fuse and did an idle relearn. It seems like that was my only problem.
Old Jun 29, 2019 | 07:52 AM
  #32
Gan Kok Boon's Avatar
Hi , thank you for your sharing. May I know which fuse you used and what does idle relearn means. Your reply is much appreciated, thanks.
Old Jun 29, 2019 | 10:43 AM
  #33
bakageta's Avatar
I considered trying to source a random fuse that would work to save money, but ultimately went with the OEM fuse from my local dealer. The part number is 1C313-RMX-003, you can see the diagram here:
https://www.hondapartsnow.com/genuin...3-rmx-003.html
An idle relearn just stops it from hunting around in the RPMs at idle, it was required for me after leaving everything apart for a few days waiting on the fuse to come in. I followed this video:
Good luck!
Old Nov 2, 2023 | 09:54 AM
  #34
Rockoa's Avatar
I just wanted to add to this thread, that if you have a P0AE1 error code in your 2011 Honda Civic hybrid you can fix it by replacing the High voltage fuse on the HB junction box . I found one on eBay for about $35 new. The error code is specifically for a main contactor relay that which can also be found on the hybrid battery junction box. I checked the realty for continuity and it was fine so only replaced the fuse. Thanks to the original post, I flipped the junction box over, pulled the fuse out, checked it for resistance, and found that it was blown. The OG post by TH saved me a ton of time and money. Thank you so much.!
Smelton22
May 23, 2019 06:11 PM
Bri
Dec 10, 2018 02:55 PM
highmiles
Mar 17, 2017 05:02 PM
Amity45
Jun 3, 2015 07:10 PM
Phototone
Feb 20, 2013 07:08 PM
