Need help diagnosing IMA/battery troubles
Old Apr 14, 2016 | 09:05 PM
Default Re: Need help diagnosing IMA/battery troubles
26 refers you to 36. Step 38 is "substitute a known good BCM." and then a "known good MCM" in step 42.
I'm going back to the P1515, which doesn't appear in the manual. I wonder if a bad BCM or MCM could throw that codes. It may be time to try a new BCM. Ebay, salvage yard or maybe check with Bumblebee batteries in Portland. They may have some spares.
Old Apr 16, 2016 | 02:22 PM
TragicallyHip's Avatar
Correct me if I"m wrong, but this here is a bad fuse and may be the source of my troubles.
Attached Thumbnails Need help diagnosing IMA/battery troubles-img_3289.jpg
Old Apr 16, 2016 | 07:19 PM
You sir are a diagnostic machine. Now comes the time to discover if the fuse is the problem or something is making it blow...
Old Apr 20, 2016 | 09:22 AM
And we have a winner! Bad high voltage fuse within the battery. Odd that it was intermittent. The cold mornings where it worked must have been because of contraction in the gap, then as the battery warmed up it would break again. Hopefully a one time thing and not due to another issue.
Old Apr 20, 2016 | 09:24 AM
Very glad to hear it. The intermittent nature kept me from considering the fuse. All in all, I think you came out ahead!
Old Feb 16, 2017 | 10:39 AM
Sweetc Nguyen's Avatar
oh crap, this is what i may be looking for! Exactly where can i find this fuse? Can you show me a picture? Cant seems to find it on my 2008 honda civic hybrid. Thanks in advance!
Old Feb 16, 2017 | 11:05 AM
  #27
I can't remember exactly where it is on the junction board, but if you look at the picture above where he's testing the fuse, you can find it on the junction board on the battery.
Old Feb 16, 2017 | 03:49 PM
  #28
Hi,
I couldn't find a photo of mine, but the fuse is the 100 amp fuse labeled as #1 in the attached part photo. You need to take the "lid" off the hybrid battery to access it. It is on the underside of the board.
Attached Thumbnails Need help diagnosing IMA/battery troubles-fuse.gif
Old Feb 16, 2017 | 09:34 PM
  #29
Hi,
Thank you so very much. I'd never dear to venture in there. This fuse... where can I get it and how much would it be? Amazon selling for $80 ?%#@$#
Old Feb 17, 2017 | 04:45 PM
  #30
I paid about $65 for it. Just search online.
This one has it for $40
https://www.parkhondaoemparts.com/pa...iagram=F648100
