My turn for IMA problems – advice needed!
Old Oct 21, 2011 | 12:38 PM
  #31
stevenvillatoro's Avatar
Arrow Re: My turn for IMA problems – advice needed!
Here's an update, and a sheepish confession.
After the replacement of my IMA pack, which did not fix my MPG issues, I prematurely jumped to blame the car and/or other factors outside of my control. Several people here and elsewhere went out of their way to give me good advice about a "relearning" process.
However (and here's the confession), I have come to realize that my lazy driving habits (very sub-optimal "mindless" driving practices) and new driving pattern (very short trips, lots more hills) were the only culprits.
By correcting my habits, I am getting superb fuel economy, as before, whenever I drive my old routes. This week, I had a chance to make a 250-mile round trip, and it was simple to get 53 MPG with A/C cruising at 70 MPH.
I got a good laugh over my situation, realizing how I had considered every factor to blame other than myself. You'd think after 10 years of hybrid driving that I'd know better!
Case closed.
Old Oct 21, 2011 | 05:08 PM
  #32
hunter44102's Avatar
Default Re: My turn for IMA problems – advice needed!
thats great Steve!
those are great numbers - you may set some records if you do 58MPH without A/C
Old Oct 21, 2011 | 09:31 PM
  #33
Gairwyn's Avatar
Think green.
Sometimes we have to do the "driver re-learn procedure"!
Glad to hear the car is doing fine, Steve.
Old Oct 22, 2011 | 02:11 PM
  #34
"Driver re-learn procedure." Hehe, good one. Yes, complacency and arrogance are dangerous human traits!
Small update today: I filled my tires today and discovered the dealer had ignored my instruction to leave the @#$% pressures (44 PSI) alone. They were at 32/30, and yet I still did remarkably well (53 MPG, as noted above) with fuel economy.
Not-so-incidentally, I discovered during this morning's fill that the @#$% tech failed to re-install TWO of my valve stem caps after my most recent service for faulty driver's side window (last month), and a third cap was unthreaded nearly to the point of falling off.
I hate that dealerships always want to monkey with tire pressures without permission.
Moral: I'm not the only dimwit at loose! Let's propose a technician re-learn procedure, too.
Old Oct 22, 2011 | 02:57 PM
  #35
It is hard to teach a old dog new tricks!!! Always check your settings after service.H
Old Oct 23, 2011 | 06:12 PM
  #36
Okay, the "official" numbers are in...
By driving mindfully over my usual route which was netting me 37 MPG in a rather careless manner, I was easily able to achieve 46.23 MPG, with little additional attention. That's a nine-plus MPG increase over the same route, with same conditions!
Clearly, with the HCH, fuel economy is driver-dependent.
I still can't believe, as a seasoned hypermiler, that I could have fallen so far off the path! Cracks me up.
P.S. Tire PSIs are now back to 43/41, but my good fuel economy was largely at horrific 32/30.
Old Oct 23, 2011 | 07:09 PM
  #37
fuelmiser's Avatar
Steven,
I had same issue was getting 4.2 L per 100 km (67 Mpg imperial) on my daily commute, then started having problems with battery. Around this time I also changed my commute slightly which put me up against some more hills. My economy fell to 5.2 l per 100 kms or 54 MPG imperial. So the poor economy wasn't all on ailing the battery.
With the new battery i am currently squeezing 4.2 L per 100 kms again while driving for economy on the old route (minus the hills). When I don't hypermile I get about 58-60 MPG Imperial.
Taking the car in tomorrow for new Good Year Assurance Fuel Max tires.
Old Oct 23, 2011 | 10:13 PM
  #38
What an interesting coincidence – today I noticed that I'm due for tires, also. How many miles on your '09? I'm at about 33,600 now.
Glad your fuel economy has returned to excellent.
Old Oct 24, 2011 | 09:19 AM
  #39
You will love those Fuel Max tires fuelmiser!!! H
Old Oct 24, 2011 | 09:54 AM
  #40
condor63's Avatar
Steve, I bought these tires and are extremely quiet and delivering the same mpg as the OEM's.
http://www.bridgestonetire.com/produ...ia_EP422_(eco))
http://www.tirerack.com/tires/tires....P422&code=yes&
