Help needed with grid charging/discharging.
Old Jan 21, 2024 | 08:38 PM
  #41
Default Re: Help needed with grid charging/discharging.
Originally Posted by 06hybrid
Thanks. I will continue to monitor the battery performance. If need to do another charge/discharge/charge cycle, should the balance charges still be 32 to 36 hours?
Any maintenance charging recommendations for the future?
I appreciate the help.
Yes, 32-36 hours. Critical that you get all cells to true 100%
For future maintenance, negative recals are a good trigger.
Old Jan 22, 2024 | 07:40 PM
  #42
06hybrid's Avatar
Thanks again. Before your most recent recommendation I was planning on going ahead with another charge/discharge/charge cycle. I disconnected the 12V battery and removed the hybrid battery but ended up reinstalling it. When I went to use the car earlier today the battery gauge showed zero bars and the engine started with the starter rather than the IMA which I thought was odd. First time that's happened during my brief ownership. Outside temperature was about 25 degrees, so not very cold at all. The IPU fan also repeated the whining/screeching noise it made previously. Once the engine started the car force charged for a bit until reaching four bars or so. The car had sat for about 48 hours. I didn't have any recals during my 60 miles of driving and the battery seemed to perform okay.
Not sure if that is significant but not exactly confidence inspiring either.
Old Jan 22, 2024 | 07:46 PM
  #43
Disconnecting the 12V completely wipes all battery data. The only thing I can account for the 12V crank is the tap voltages were too low for the car to start.
Yep. Not confidence inspiring, but 60 miles of no recal driving doesn't suck.
Old Jan 22, 2024 | 07:50 PM
  #44
06hybrid's Avatar
Thanks for the quick reply. Can grid charging/discharging improve self discharge? From what I've read from your other posts, it sounds like self discharge is the common issue with the HCH2 battery.
Old Jan 22, 2024 | 07:58 PM
  #45
Nothing improves SD. The only hope is that they are all equally crappy, and all you need to do is drive it VERY regularly.
Old Jan 23, 2024 | 07:48 AM
  #46
06hybrid's Avatar
That makes sense. I thought that my old Insight battery was crappy, but in comparison it was fantastic compared to this car.
I will continue to monitor the performance.
Thanks again.
mr1997
Aug 27, 2020 05:21 PM
michael.b
Oct 22, 2018 11:37 PM
paulk
Jan 25, 2018 03:58 PM
jwillvin
Oct 4, 2017 08:13 AM
ldychipmnk
Jul 28, 2010 12:41 AM
