HCH2 - IMA battery reconditioning
Old Dec 15, 2020 | 11:41 AM
  #51
cuky's Avatar
Default Re: HCH2 - IMA battery reconditioning
Hello I finally managed to build my grid charger, but the battery heats up quickly, Can someone help me, how to connect the PWM controller on the HCH2 Fan. Where do I connect the (+) and (-) cable from the PWM controller to the HCH2 Fan? Thanks
Old Dec 15, 2020 | 03:22 PM
  #52
Coval's Avatar
Training wheels fitted
The HCH2 requires a PWM controller to properly drive the in-car fan, or you can short the PWM cable to ground and drive the fan with a 12V/10A power supply (it's powerful like a leaf blower). Coval installed a simple 12V 80 or 90mm fan in the exit duct blowing into the trunk (thus it sucks air through the battery from the interior). In my case in, this was not sufficient except in the coolest months.
Yep, the 12v computer case fan isn't powerful enough and only does the trick in cold weatber. Unfortunately I don't know how to rig up car's own fan, but it seems like a sensible solution.
Good luck and keep safe!
Old Dec 16, 2020 | 08:47 AM
  #53
Coval's Avatar
While I am here, let me wish you all a Merry Christmas and a safe, Happy New Year!
Old Dec 16, 2020 | 10:56 PM
  #54
Kevinmce's Avatar
Have a look here for my working schematic for the fan controller.
https://www.greenhybrid.com/forums/f...tml#post267269
I think I also link the pwm controller that I bought, but if you search aliexpress for pwm controller I'm sure you can find a similar one. Also the pwm controller should have it's pwm signal disconnected with a 12v relay. Can be a standard automotive relay.
nrodgsxr
Oct 12, 2020 12:18 PM
rmacgowa
Jun 22, 2020 06:57 AM
Broke
Apr 23, 2020 08:25 PM
jeb101
Mar 20, 2019 07:13 PM
mrklean
Apr 23, 2017 10:51 PM
