HCH2 - IMA battery reconditioning
Old Sep 2, 2017 | 04:22 PM
  #41
Lukasz555's Avatar
Default Re: HCH2 - IMA battery reconditioning
That should help get the data on a comparable level.
Hopefully, you're going to get frustrated with the 15 hours it takes to get to 158V
I have finished 3 charge cycles.
below I present notes
1 cycle
charge time 25h
peak voltage 186 V
time to 158 V - 7h 50 min.
158V - 106V - 4h 25 min.
TOTAL DISCHARGE TIME 12h 15 min
2 cycle
charge time 25h
peak voltage 188 V
time to 158 V - 11h 30-40 min
158V - 106V - 2h 40 min
TOTAL DISCHARGE TIME 14h 20 min
3 cycle
charge time 24h
peak voltage 189,8 V
time to 158 V - 12h 40 min
158V - 106V - UNKNOWN (I finished discharge at 80 volts)
TOTAL DISCHARGE TIME ~ 15h 20 min
are these good results?
Should I make another cycle?
Old Sep 2, 2017 | 06:16 PM
  #42
Big increase in 2nd
Small increase in 3rd
Each charge went a little higher.
That's exactly how you want it to go.
You can do a 4th, but it's unlikely you'll see any significant gains. Assuming ~355mA current during discharge, that's 4500mAh capacity on a 5500mAh pack.
I'd say you're done. Charge and go.
Old Jul 16, 2020 | 03:02 PM
  #43
cuky's Avatar
Hello, I have a 2007 Honda Civic European and I would like to try Building a HCHII grid charger but I needed the construction scheme, step by step.
Please help me with the scheme.
Thank you and sorry for my English
Old Jul 22, 2020 | 01:25 PM
  #44
Coval's Avatar
Training wheels fitted
As rightly pointed out by S Keith, the schematic applied to a previous generation, can't recall what forum I found it on.
The following depicts the one I built, as you can see I can't draw to save my life
Old Jul 22, 2020 | 01:53 PM
  #45
First, that won't work for an HCH2, and 2nd, you should credit the source.
Old Jul 23, 2020 | 01:33 AM
  #46
Coval's Avatar
I am sure I posted the following pics already, but this is what finisher charger looks like:
Old Jul 23, 2020 | 08:05 AM
  #47
Awesome. Glad you revisited this.
Old Jul 23, 2020 | 11:07 AM
  #48
cuky's Avatar
Hi Coval,
thank you very much for your help and quick response. I liked to build my own network charger,
but I wanted a step by step diagram and if possible with pictures of a grid charger / unloader, without always having to remove the battery from the IMA.
Thank you in advance
Old Jul 23, 2020 | 11:44 AM
  #49
The HCH2 requires a PWM controller to properly drive the in-car fan, or you can short the PWM cable to ground and drive the fan with a 12V/10A power supply (it's powerful like a leaf blower). Coval installed a simple 12V 80 or 90mm fan in the exit duct blowing into the trunk (thus it sucks air through the battery from the interior). In my case in, this was not sufficient except in the coolest months.
Old Jul 26, 2020 | 09:46 AM
  #50
cuky's Avatar
Hi S Keith
Thanks for the help, but I was unsure of: what advice? the PWM controller for HCH2 and which one? or start the fan with a 12V / 10A power supply.
Thank you
